QRZ Forums   QRZ Ad 554
 Forum Home   QRZ Home
QRZ Ad 1997
QRZ Ad 1992
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Go Back   QRZ Forums > Ham Radio Tech > Questions and Answers
Reply
Thread Tools Display Modes
  #1
Old 11-05-2009, 09:47 AM
ZS5J ZS5J is online now
Ham Member
Unhappy FT-1000 D transformer hum on TX
Hi
I purchased a very nice condition FT-1000 D 2 weeks ago. It performed well when I first installed it in my shack. Now it has developed a hum when I transmit. It seems to me like a ground loop problem, so I took the covers off, and went about tightening all ground earthing screws, paying particular attention around the transformer. I also put a snap-on ferrite around the long wires going to the on/off switch. I put it all back together, but the loud hum is still there. It is not there on receive - only when I transmit, and when the built-in power supply is under load. The hum is loud externally, and also gets transmitted with the output signal. The more power I run, the louder the hum becomes. No external equipment is connected, just the power cord, antenna and a very good earth cable going to the ground lug. Any advice please ?
Thanks and 73
John, ZS5J
  #2
Old 11-05-2009, 12:30 PM
Ham Member
Talking THE HUM HAS BEEN RESOLVED
Sorry, after having posted the previous post, I decided to try one last thing. I powered up the rig - with the covers off, noting that the hum was still very loud on TX with the covers off. I then proceeded to fiddle with the wires coming from the output of the transformer - 48 volt dc ?. By fiddling with these 4 DC output wires, I found that they were making poor connection in the plug that they terminated in. By moving these wires and plug, I was able to totally remove the hum. While moving the wires, I noticed a spark inside the connecting plug, further indicating that there was a poor connection. I removed the plug, crimped each of the 4 connectors, and re-inserted the plug - now they were making proper contact, and no more hum.
John, ZS5J
  #3
Old 11-05-2009, 02:28 PM
G0WBR G0WBR is offline
Ham Member
Location: IO90OT  7 Southover Way, Hunston, West Sussex PO20 1NY
Smile
Quote:
John, ZS5J
Hi
I was going to mention before I saw your second post that I have an IC-706 which did exactly the same thing and I concluded it must be the power connections so made sure they were well secured and no more hum. I always now check that before anything else. Well done glad you got it sorted.
Regards
Tim - G0WBR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
