QRZ Forums   QRZ Ad 25
 Forum Home   QRZ Home
QRZ Ad 2038
QRZ Ad 1992
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Go Back   QRZ Forums > Ham Radio Tech > Questions and Answers
Reply
Thread Tools Display Modes
  #1
Old 11-05-2009, 12:42 AM
K1HON K1HON is online now
Ham Member
Default 10 meter wire length question.
I have a 20 meter dipole that I decided to add 10 meters to. I have added 8.5 feet of wire on either side of the balun. I can now get it to tune on 10 meters but not all of the band. I am using the limited built in tuner in the FT-450AT which can tune 3:1 or better. I can get it to tune up on 28.5 mhz all the way to 29.6 mhz. Below 28.5 mhz the tune fails, I'd like t get it to tune down to 28.3.
Do I cut the wire or does the wire need to be longer in order for me to be able to tune it to a lower freq? How much should I cut or add roughly?
Thanks!
  #2
Old 11-05-2009, 12:46 AM
WB2WIK WB2WIK is online now
Ham Member
Longer.
3-1/2" per "side" of the dipole, per MHz at 10m.
If you want to lower the resonant frequency from 29 MHz to 28 MHz, you need to add 3-1/2" of wire to each "side" (or leg, or half) of the dipole.
However the problem you have isn't guaranteed to be that -- could be something else, like the influence of the 20m dipole screwing it up.
How far apart are the 20m and 10m wires? Sounds like they are "together" at the feedpoint, but how far apart at the wire ends?
  #3
Old 11-05-2009, 12:55 AM
Ham Member
They are both in an inverted V (attic installation) The 20 meter wire is on top with the 10 meter wire underneath. The ends of the 10 meter wires are about a foot directly below the 20 meter wire section. Up near the balun the wires are fed from the same point.
Quote:
Originally Posted by WB2WIK View Post
Longer.
  #4
Old 11-05-2009, 12:59 AM
Ham Member
Quote:
That should work. Try making the 10m wires longer and see what happens.
  #5
Old 11-05-2009, 01:44 AM
AG3Y's Avatar
AG3Y AG3Y is online now
Ham Member
Putting up a good antenna is partially science, and partially magic ! You start with the calculated figure, and then you "tweak" the lengths a bit to get the best all around compromise.
I always cut my antennas long, so I can end up clipping off the wires to achieve the desired match.
It is a lot easier with a device such as the MFJ antenna analyzer, but back in the "olde days" we used SWR meters, or some kind of relative RF field strength meter.
Good luck! Jim
__________________
"He is a Ham God of QRZ" NN4RH
Member S.P.A.R.
Member A.R.R.L.
  #6
Old 11-05-2009, 01:55 AM
Ham Member
I also just noticed I used 16 gauge stranded instead of the 14 stranded that the 20 meter wire is made out of. Will that present any issues?
  #7
Old 11-05-2009, 01:58 AM
Ham Member
No, not at all. Impossible.
  #8
Old 11-05-2009, 02:18 AM
AG3Y's Avatar
Ham Member
The only problem you would experience is that the 16 ga will not be as strong as the 14. But if the 14 is carrying the weight, you are probably better off using the 16 for the shorter antenna, as the total weight of the system will be less!
Are you installing this as a "flat top" or "inverted VEE" style antenna ?
__________________
Member S.P.A.R.
Member A.R.R.L.
  #9
Old 11-05-2009, 03:05 AM
K7FE K7FE is offline
Super Administrator
10 meters is a large band and difficult to cover all of it without retuning your antenna. Consider making a two wire per side cage dipole for 10M which can be made to have a VSWR bandwidth that covers the entire band. Use about a 12 inch spacing between the wires. The length will end up a little shorter than a single wire dipole for resonance due to the additional capacitance.
Trim the 20 meter element for the lowest VSWR first and then the 10meter one because of the interaction.
Terry, K7FE
__________________
Terry Graves, K7FE
Editor QRZ.COM
  #10
Old 11-05-2009, 03:08 AM
Ham Member
Terry, K7FE
Terry, I doubt he needs to cover higher than about 28.5 MHz...unless he wants to use the same antenna for FM above 29 MHz. I admit I'm a boat anchor lover and also use 10m AM around 29 MHz when the band is really open, but the last time that happened was probably in 2003. Hopefully we're looking forward to those "AM times" again -- maybe.
When F2 comes back to 10m, my AM station gets fired up again!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
