QRZ Forums   QRZ Ad 1909
 Forum Home   QRZ Home
QRZ Ad 1997
QRZ Ad 1995
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Go Back   QRZ Forums > Ham Radio Tech > Questions and Answers
Reply
Thread Tools Display Modes
  #1
Old 11-05-2009, 12:01 AM
KB1PRX KB1PRX is online now
Ham Member
Unhappy HTX-202 Output
I Had To Sell All My Equiptment Now All I Got Is This HT I Traded For And Yes I Knew There Was No Output. I Just Didnt Know Why?? I Programed It Just Like My Old One.(HTX-202) But When You Key It The Bars Dont Go Up And It Doesnt Transmit At All,On Any Freq. My Only Thoughts Would Be That The Outputs Are Bad? Any Thoughts Would Be Greatly Appreciated. Since Im Out Of Work Im Very Limited. Thank You And 73, KB1PRX
  #2
Old 11-05-2009, 12:34 AM
K9ZMD's Avatar
K9ZMD K9ZMD is online now
Subscriber
TX Lock Out? (Well, you could always hope it's that simple!)
  #3
Old 11-05-2009, 12:53 AM
Ham Member
Default No Output
I Did Check That But Thank You Anyway.
  #4
Old 11-05-2009, 05:07 AM
K7MH's Avatar
K7MH K7MH is online now
Ham Member
Is It Possible That The Antenna Connection Has Come Loose On The Inside Of The Radio?? Sometimes The Connector Gets Loose And Turns, Breaking The Connection.
Ok, that's a pain and makes typing pretty slow for me. Thought I'd give it a try though.
__________________
CW is the KEY to ham radio.
  #5
Old 11-05-2009, 05:28 AM
Ham Member
Default No Output
Anythings Possible Ill Check That Thank You
  #6
Old 11-05-2009, 06:16 AM
Ham Member
Default Still No Output
I Checked The Ant Connections And Their Fine I Think The Problem Might Be Something Shorted Out. Someone Got Inside To Replace The Internal Battery
And Did A Real Bad Job At That. Im Not Too Optimistic Anymore After Seeing That Mess. For Now I Put It Back Together Until I Can Order A Battery Holder Like WB3GCK Did That Looked Like A Clean Job. Then Ill Have It Looked At.
I Cant Send It Out Looking Like That. Thank You For All Your Help. I Guess
Ill Be Off The Air For A Little Longer. 73
  #7
Old 11-05-2009, 09:20 AM
N7DXT's Avatar
N7DXT N7DXT is online now
Ham Member
A story goes around about those that they don't like to be operated with 12V connected in the top jack while a battery is installed - because a zener diode in the regulating circuit gets too hot and overheats the final amp.
It seems a bit fishy to me and I don't know how much there is to it - I've never been into my 202 to see where the parts are but supposedly the diode and the final are physically too close together, but the diode can be repositioned and supposedly that was routinely done by service shops.
Of course if the final is cooked it would probably be not worth repairing, but I have seen (and it would depend on the construction) finals that were thought fried that just needed resoldering, but that has been in higher watt stuff than a 202.
It would be nice if you could bring the rig back to life with a simple fix - they are a nice, tight HT, if a bit of a bugger to set up the memories and so forth with their somewhat cryptic button labeling.
http://www.repeater-builder.com/rbtip/ has a lot of info on the 202 including this: http://www.repeater-builder.com/radi...ent-tx-fix.txt a tale of poor grounding at the antenna connector which maybe of interest to you, as well as complete service manuals & parts lists.
Good luck!
__________________
Posting from an undisclosed location in the Nation of Bitter Clingers!
  #8
Old 11-05-2009, 03:53 PM
K7MH's Avatar
Ham Member
Good grief...It's time to drop the caps for every word!
__________________
  #9
Old 11-05-2009, 04:26 PM
EMRAD EMRAD is offline
QRZ Member
Default HTX-202
N7DXT wrote, "A story goes around about those that they don't like to be operated with 12V connected in the top jack while a battery is installed - because a zener diode in the regulating circuit gets too hot and overheats the final amp".
I too have heard that one from a dealer in a popular ham radio shop.
Another thing to look for that I can tell you from experience: The metals they use in the radio contacts and the stock antenna center pin don't seem to like each other. I used to get this yucky black corrosion on the center pin of the antenna that broke contact, I kept having to scrape it off to make a good contact. Perhaps it might have caused the demise of your HTs finals. When I went with an after market antenna the problem no longer occurred.
Emrad
  #10
Old 11-05-2009, 04:30 PM
W5LDA W5LDA is online now
Ham Member
Why do some always have to gripe on every thread they read? Of all things,heaven forbit someone uses caps,,,geeze!
__________________
Sometimes I wonder whether
the world is being run by smart
people who are putting us on
or by imbiciles who really
mean it.
-Mark Twain
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
