QRZ Forums   QRZ Ad 1608
 Forum Home   QRZ Home
QRZ Ad 1994
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 2038
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Go Back   QRZ Forums > Online Swapmeet > Ham Radio Gear For Sale
Reply
Thread Tools Display Modes
  #1
Old 10-31-2009, 08:14 PM
NT4I NT4I is offline
Ham Member
Default Broadband terminated antenna
Broadband Terminated Inverted Vee or Dipole
This is a home brew antenna that works well covering 160 to 6 meters with a flat or near flat VSWR.
It is overall 220 feet long and fed directly with 50 ohm cable.
The center balun is a 16 to 1 ratio and coming off each side of the balun is 110 feet of wire. At the end of each leg is a 400 terminated load which should go to a ground rod (NOT INCLUDED). Supporting the 110-foot length of wire is an end insulator. Also included with this package is a length of wire to connect both ends of the terminated load together. This wire would lay on the ground, can be buried or not used.
Power handling is approx. 500 watts SSB or CW.
Performance equals or exceeds that of a common dipole on all bands except 160 where it is a db or so down over a full size dipole installed at common heights.
The benefit of using this antenna is not only broadband operation but because it is terminated, the noise is much lower over a dipole and a tuner is not required. It’s installed and used regularly so you are welcome to hear it on the air or come look at the VSWR curve personally or see it up close.
Price is $85 shipped or $75 picked up. I don’t not have any pix’s. If interested or if you want to talk about it, please call me direct at (804) 781-6856, Vince.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
