Hi,
I need to know some things so there is no mis-understandings.
When was this bought, how many owners.
have you ever keyed a amp with the flex and, how is the darling transistor (major issue)
The darlington transistor is used to key the relay on the newer linears.
They will blow real quick as I found out on my flex!
If you don't know, please check with a ohm meter from the back of the db-9 connector. If this is blown, It would be a major fix from flex.
What is the serial number please.
Any known issues.
Thank you
