QRZ Forums   QRZ Ad 1956
 Forum Home   QRZ Home
QRZ Ad 2137
QRZ Ad 55
QRZ Ad 2143
QRZ Ad 2136
QRZ Ad 1995
QRZ Ad 1440
Google Search
QRZ Web
Donate to QRZ
Contributions Accepted
  #1
Old 03-06-2009, 12:57 PM
G0YAP G0YAP is online now
Ham Member
Smile Yaesu FT8900 Mic Mod
Hi. I own 3 Yaesu FT8900s and these radios are fantastic but.... I kept getting reports that my audio was 'too sharp' and very harsh to listen to. This was found to be the case with all 3 of my rigs. I opened the mic up and after removing the mic head from its 'cup' I found a small plastic disc placed between the mic and the holes in the outer case of the mic. It was not bonded in so was removed just by tipped the case up side down. I re-assembled the mic and WOW!! what a difference!! The reports now are very good, the harshness has gone, the audio is just as loud but clearer. I have received a good many reports from other stations I work on a daily basis, and all agree my audio has got a lot better. I have now modded all 3 of my 8900s and everyone I know has now done the same. I,m not sure why yaesu put this disc in, but the audio is much better without it. The good thing is, if you don,t like it, just replace the disc and you,re back to the original spec. I should think the FT8700 and the FT8800 are the same as they use the same mic, but I do not own these radios so can,t be 100%..By the way, I am talking about the MH-48 DTMF mic, not sure about the non DTMF mic. Best 73s Ian G0YAP, Diss , Norfolk, UK
  #2
Old 03-06-2009, 08:47 PM
W3NRL W3NRL is online now
Ham Member
Default FT8800 Mic
ok, took my ft 8800r mic apart and found no disc in the mic and i do have the MH-48 DTMF mic, maybe i am looking in the wrong place?
thank you
__________________
Best of 73
de w3nrl
Nick
  #3
Old 03-07-2009, 04:52 PM
Ham Member
Default FT8900 Mic Mod
Hi Nick,
Remove the pcb board (3 silver screws and one little one holding the ptt micro switch) pull the mic head out, remove the rubber surround and the little black plastic disc should be under there, as it falls out, you should see right thru to the 2 little holes in the case and daylight. Hope this helps. Ian
  #4
Old 03-19-2009, 11:32 AM
M0PZT's Avatar
M0PZT M0PZT is offline
Ham Member
Just done this on my MH-48 (used with FT-8800E) - helps a fair bit. This page may also help if you want to do a little bit of soldering: http://members.cox.net/wb1aex/8900.html
__________________
Charlie - M0PZT @ GB7ESX.#31.GBR.EU
MB7ICF 6m/70cm EchoLink Gateway, MB7UCF APRS Digipeater
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
