QRZ Forums   QRZ Ad 1903
 Forum Home   QRZ Home
QRZ Ad 55
QRZ Ad 2143
QRZ Ad 2136
QRZ Ad 1995
QRZ Ad 1440
QRZ Ad 2137
Google Search
QRZ Web
Donate to QRZ
Contributions Accepted
Go Back   QRZ Forums > Ham Radio Tech > Questions and Answers
Reply
Thread Tools Display Modes
  #1
Old 12-04-2008, 12:25 PM
KC9NPL KC9NPL is offline
Ham Member
Default do all ht's have crossband repeat?
iam looking to buy a new HT and i have been wondering which manufacture makes the better radio and if they all have the crossband repeat feature?
  #2
Old 12-04-2008, 01:10 PM
K8ERV's Avatar
K8ERV K8ERV is online now
Ham Member
Location: Beautiful Downtown Colorado. (Montrose, SW corner)
No, I think only a few have this feature. I have an Icom W32 that has it but I have not tried to set it up, no need. I don't know which others, but I'm sure if one has it it will be stated loudly, and will cost more.
TOM K8ERV Montrose Colo
  #3
Old 12-04-2008, 01:26 PM
N8EKT's Avatar
N8EKT N8EKT is offline
Ham Member
Certainly not
And cross banding with an ht is just begging for problems.
Unlike mobile radios, hts don't have cooling fans or large heat sinks so they could easily be damaged in a cross band mode.
Hand helds are designed for short range, short duration transmissions.
Attempting to do otherwise will usually lead to disaster.
  #4
Old 12-04-2008, 01:33 PM
KG4RUL's Avatar
KG4RUL KG4RUL is online now
XML Subscriber
Location: EM93wa: Ladson - about 18 miles NW of Charleston, SC
Wink
The single band models most definitely don't!
  #5
Old 12-04-2008, 01:51 PM
KC9MUK KC9MUK is offline
Ham Member
I am not aware of any HTs currently on the market that do crossband repeat. There are some that offer dual receive.
__________________
ECHOLINK NODE#401099
  #6
Old 12-04-2008, 02:01 PM
KJ4GXU KJ4GXU is online now
Ham Member
Perhaps you mean do all HT's have support for repeater offsets/split operation, And the answer there would be that yes, just about all of them will.
I mean no insult if you are actually asking what you said and did not mean otherwise but I'll explain the difference below just in case you did ask the wrong questions.
I believe that Crossband repeat would mean the radio acts as a repeater receiving in one band (Such as 2 meters) and transmitting in another (Such as 440).
Repeater offsets or Split operation means that within one band you can receive on one frequency (147.39) for example and transmit on another (147.99) without having to manually change frequency. When you're not transmitting your radio listens on one frequency the repeater output, when you transmit the radio switches to the repeater input frequency. Once you release the PTT key the radio switches back to the repeater output.
This allows real time repeater operation where if you operated a simplex repeater you'd transmit, the repeater would record what you send then when you release the PTT the repeater would retransmit what you said. the result is that anyone within simplex range would hear you twice and you'd hear your own transmission come back to you.
Again, if you already knew this there was no insult meant, but if you had your terminology confused hopefully this will help.
Eric
kj4gxu
  #7
Old 12-04-2008, 02:35 PM
N2RJ's Avatar
N2RJ N2RJ is online now
Ham Member
Quote:
The FT-51R from Yaesu offers full duplex and cross band repeat.
Of course it's a discontinued model now...
__________________
The poor people of Haiti lost everything after the deadly magnitude 7.0 earthquake. Please help.
  #8
Old 12-04-2008, 03:59 PM
Ham Member
My guess is they dropped it from the lineup because there really would be very limited circumstances in which a crossband repeating HT would be useful. I can see it's usefulness in mobile or base stations, but not in an HT.
__________________
  #9
Old 12-04-2008, 04:33 PM
KD7QPW KD7QPW is offline
Ham Member
I have a FT 530 that will cross band repeat, I don't remember if it's in the menu setting or if I have to do a mod.. That should tell ya how much I would use it for that! However setting up a dual band mobile would work great for that, but then I didn't really help answer your question much.. But to try and answer the question I read: no, but some will or do.... J
  #10
Old 12-04-2008, 04:43 PM
KF6NFW KF6NFW is online now
Ham Member
Quote:
Originally Posted by N8EKT View Post
Certainly not
Pay attention to this comment, he is absolutely correct.
I learned the hard way as a new ham in 1997 with an FT-470. I love the radio but puting it into cross band mode fried it in about 30 minutes tops, or how ever long it took me to walk to the corner store and back.
I have two FT-470's had one on the bench at home connected to base antenna and the other with me.
Now I have two dead FT-470's soon to be resurrected into one as the cost to rebuild the other outweighs the cost of replacement by a good margin. As quoted by Yaseu it was going to cost $235 and that was before the screen froze and turned black, the second one just has minor abuse issues, and can be saved from the parts from dead subject "A"!
Dont use the Handheld as a crossband repeater, I have had much better luck with using the mobile/base as such for a much longer time(about 4 months now, dedicated) and have no issues with it besides the design flaw that all had until the second release.(TM-V7A)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
