QRZ Forums   QRZ Ad
 Forum Home   QRZ Home
QRZ Ad 1440
QRZ Ad 2137
QRZ Ad 55
QRZ Ad 2143
QRZ Ad 2136
QRZ Ad 1994
Google Search
QRZ Web
Donate to QRZ
Contributions Accepted
  #1
Old 08-18-2008, 04:48 AM
KE7AQL KE7AQL is offline
Ham Member
Default Homebrew HT Antenna?
This is a pretty simple question, but my internet searches have been unfruitful so far.
I want to make a simple replacement antenna for my HT, what would be required for this?
I know that without a good ground(plane) it is hard to get the impedance down to 50 ohms, so what is the solution? My gut tells me that I need to make a coil to match it, is this right?
  #2
Old 08-18-2008, 03:04 PM
K9STH K9STH is online now
Head Moderator, QRZ Staff
Cut a piece of stranded "hook up wire" about 20 inches long. Then strip one end and solder it to the appropriate connector to fit the antenna jack on the portable. This will result in a piece of wire about 19.5 inches long which will be a full quarter-wave on 2-meters and a 3/4 wavelength antenna on the 70 cm band.
This antenna will have at least 10 dB "gain" over the normal "rubber ducky" antenna that most portable units are equipped from the factory on 2 meters and about 13 dB gain over the "rubber ducky" antenna on the 70 cm band.
Motorola used to sell these "dangle" antennas for use with their commercial two-way portable radios and they worked very well.
By the way, unless you actually have a Motorola product you don't have an "HT" but have a "portable" or "hand held" radio. Remember, "HT" is a registered trademark of Motorola as is "handy-talkie" and "Handi-talkie".
  #3
Old 08-19-2008, 02:45 PM
W4INF's Avatar
W4INF W4INF is offline
Ham Member
I run a Pryme RD-98 on my VX-170, its a great antenna... much better than any stock rubber dummie load.
Andrew
__________________
http://rogertango.com/logbook.aspx
You might be in my log book
Best quotes of 2009
Quote:
Originally Posted by n8yx View Post
Play stupid games - win stupid prizes.
Quote:
Originally Posted by WA9UAA View Post
One of the biggest dangers of being out in the woods alone is being out in the woods alone!
  #4
Old 08-21-2008, 06:38 AM
W2AJW's Avatar
W2AJW W2AJW is offline
Ham Member
Glen, I just wanted to chime in and say that after seeing you post this in another thread I made one for my HTX-202 that serves as my "base" here at home and it works great. Since it never actually goes anywhere, I actually cut a length of metal coathanger to size and soldered it into an SO-239 to BNC adapter to use on the '202. MUCH better than the rubber dummy load.
So I just wanted to offer my thanks for the suggestion and to reinforce that it works great.
__________________
Andy
ex-KB0WJO
  #5
Old 08-21-2008, 07:55 AM
KB1KIX's Avatar
KB1KIX KB1KIX is online now
Ham Member
In addition to what Glen said (though I'll still call 'em an HT!).....
There is one article available on the ARRL site - and you don't even need to be a member for this one.
http://www.arrl.org/tis/info/pdf/9803037.pdf
Like INF has said, anything is better than the dummy load that comes from the factory. All my HT's (sorry Glen) have an aftermarket antenna. They average around 15 inches or so, turn heads often, but they work like 10 times better.
OK, in this crowd, I should be more accurate, about 10 or so db gain better...
Jonathan
__________________
Yes, I am an ARES DEC. However, 97.113(a), should stay as it is!!!!
My blog (new, will be adding a lot of ham radio links and such)
www.kb1kix.net
Good amateur radio podcasts:
Soldersmoke: http://www.soldersmoke.com/
This Week in Amateur Radio: http://www.twiar.org/
People
Eating
Tasty
Animals
  #6
Old 08-23-2008, 04:03 PM
AE1PT's Avatar
AE1PT AE1PT is offline
QRZ Administrator
By the way, unless you actually have a Motorola product you don't have an "HT" but have a "portable" or "hand held" radio. Remember, "HT" is a registered trademark of Motorola as is "handy-talkie" and "Handi-talkie".Glen, K9STH
Hmmm, sort of like placing a TM on "PL" For my thinking, the translation is "Handheld Transceiver." Try getting a TM or copyright on that!
Another material that works well for homebrew HT whips is stainless steel wire in small gauge--14 or 16. I use this for my 1/4 wave 6M whip. Be sure to twist a little loop on the end though.
__________________
73 DE PATRICK, AE1PT
SKCC #4473
My DX Logbook
"Time is the coin of your life. It is the only coin you have, and only you can determine how it will be spent.
Be careful lest you let other people spend it for you.
" Carl Sandburg
My Blog--Blogmudgeon-- http://www.blogmudgeon.com
  #7
Old 08-23-2008, 04:53 PM
Back in the early 1970s several Japanese radio manufacturers started advertising in the U.S. amateur radio magazines their products as "HT", "Handi-Talkie", "Handy Talky", and so forth. Within less than 48 hours all of those magazines got "cease and desist" orders from the Motorola legal department, backed up by the United States government, for trademark violations. Those Japanese manufacturers had to immediately revise all of their advertisements.
It is the same thing for "PL" and "Private Line" (which are Motorola's trademarks for CTCSS). General Electric did the same thing for "CG" and "Channel Guard" (which were their trademarks for CTCSS).
Now it doesn't really "bother me" to see "HT", "PL", and other Motorola trademarks used generically. However, every once-in-a-while Motorola does "flex its muscles" and people do get a "nasty-gram" from their legal department for using the trademarks for products other than those manufactured by Motorola. Also, Motorola is VERY protective of their programming software and if someone obtains a copy without paying a transfer fee to them that person WILL get a VERY "nasty" letter demanding payment of the fee and, unfortunate to the person who got the letter, Motorola's claim will hold up in court.
It is like Xerox. That company will defend its trademarks very actively to keep the name from becoming a "generic" term for copying.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
