QRZ Forums   QRZ Ad 2028
 Forum Home   QRZ Home
QRZ Ad 1997
QRZ Ad 1992
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Reply
Thread Tools Display Modes
  #1
Old 03-22-2008, 07:12 PM
M0TIU M0TIU is offline
Ham Member
Default MFJ 1798 vertical antenna
Has anyone experienced difficulty in tuning this antenna. I have been using and antenna analyser and have horrendous difficulty in tuning the bands on it.
  #2
Old 08-24-2008, 10:51 PM
KC7NOA KC7NOA is online now
Ham Member
Default Mfj-1798
I have read that the reason that the antenna is horrible to tune is to two problems, one -- the coax connector at the base of the antenna has a broken center connector at the pl-259, the other affects the lower bands, ie - 30m down, the 4 similar capacitors on the pcb at the top of the antenna( that has the tap for 2-meters) needs to be replaced with 390pF that are RF rated. I have Bought some off of ebay and still waiting for delivery.
The symptoms on 75/80 and 40 is that as you get close to the resonance say at 3.950 the impedance goes up above 3:1 ...
Ill know more for sure when my capacitors show up and i install them ... im also going to try to add 160M by adding 3/4Y to the end of the loaded section.
KC7NOA
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
