I have owned a VX7R for over two years and have had excellent results with it. I have it connected to a 45 watt amp in my 4 runner and really like the versatility of the different bands and the weather band. I have it connected to a Diamond Antenna for 2 mtr, 440, and 6 mtr band. Plenty of memory for all the repeaters. Great Radio!!! Good luck.
N0CQV
Own both. Great receive on both radios. Both operate 5 watts, sma connector and small handheld package ideal for one handed operations. VX-7R has a dual band display, FT-60R does not. Tough decision you have to make but another thought is the external speaker/microphone...VX-7R has a screw type for it's microphone and the FT-60R is simple. With all the opinions the finally decision will be yours and i still use both back and forth.
__________________ Keith G. Wucherer, N2OBS
Echolink Station N2OBS-L
Echolink Node 99729
Repeater 146.865 MHz
Repeater 443.775 MHz 123.0 PL
Monitoring 145.67 MHz DV
Summerville, South Carolina
Ut Totus Alius Deficio
I chose the FT-60R over the VX-7R because on the FT-60R I can use the AA-pack and get a full 5 watts out for ecomm use. On the VX-7R I believe you're limited to 0.5 watts when on AA batteries .
Thanks for the replies...I think. Still can't decide which one to get, they both sound like good radios. I could suffer the wrath of the wife and get both but I don't think I want to go through that!
Those of you who have had these HT's, did you have to purchase a carry case of some sort or did the belt clip that came with it provide a stable enough solution?
For the FT-60R I just use the belt clip. Back when I had a Kenwood TH-79A(D) I used to put it in a faux leather case. The case ended holding in sand/dust/etc. And it was also annoying to take the case on and off to get to the battery.
without a shadow of a doubt, I have had 2 - over nearly 5 years and never once had a problem, they are fun as well as hugely practical and can be "played with" to some extent as well as waterproof which is a real bonus if you get out and about. The only downside with all these, is that if you use it mobile with the cigar lighter atachment, they get really hot to the extent where they will actually malfunction - mine switched itself off before I realised what was happening. I hasten to add that this a design safety feature, since then I limit my operating when mobile to short overs and reduce power where possible, maybe I was asking too much of the rig.
Better that is shuts down before it fries itself. That gives you an excuse to buy a mobile rig now.
My elmer has an FT-60 I and I got a VX-7R. The VX-7R has a dual receiver, which allows you to monitor two repeaters or other frequencies at the same time. The VX-7R is compact, but still capable of being ergonomic. The menus are easier to understand than the FT-60, but the weather alert is not described well in the menu. The VX-7R has a sensor to tell you what the temp inside of the rig is so you know how hot you are getting, the FT-60 does not. The VX-7R can run directly from the DC input but it gets hot and cannot charge at the same time. The VX-7R has a voltmeter which can tell you the voltage of whatever source it is running. This is very critical when running the rechargable pack down real low as the pack, nor the radio causes a shutdown when the voltage drops below 5. Going below five volts places the radio in Dry-Cell mode and assumes you have a AA pack in there.
ke6vfa states that the AA pack is a weakness on the VX-7R for emmcom, but the VX-7R has features that make that a somewhat moot point:
1. With the appropriate pigtail adapter the VX-7R will run off a gel-cell directly
2. The recharging base uses the AC adapter, which means you could probably use the 12 volt adapter or the pigtail as well. With a second pack you could potentially run on battery packs alone.
3. If push comes to shove you could rig an 8AA pack with the pigtail and power the rig directly the same way as a gel cell. You can rig this with C and D cells as well. but you will need to find a way to mount this.
3a. The 8AA pack will also work with 2 above and actually get more runtime out of the AA cells than powering the rig directly.
Ah! It would, if I didn't already have several - FT7800, FT897, FT290, as well as 2 x VX-1 and a VX-2........just used the VX-7 in my company car so it didn't need plumbing in.
