QRZ Forums   QRZ Ad 416
 Forum Home   QRZ Home
QRZ Ad 1995
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 2038
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Reply
Thread Tools Display Modes
  #1
Old 03-07-2008, 05:29 PM
K0JJM K0JJM is online now
Ham Member
Default Super Antennas - what do you know about?
I started a thread a few weeks ago about a "portable" beam antenna to use for my cabin in Michigan. Thanks for all the input! I noticed in the March QST "Antenna Special" a newcomer that might fit the bill. It is the Super Antenna YP3 - six band 3 element Yagi. I have emailed the company for more info (no details on the website about the antenna), but was wondering what experiences others have had with antennas from this company and if anyone has used / seen any of their portable Yagi types? Apparently they have had a two element version out before.
  #2
Old 03-09-2008, 02:08 AM
KD8GKR KD8GKR is online now
Ham Member
you may also want to look at a Spider Beam http://shop.dx-is.com/product.sc?cat...=3&productId=3 as a portable option. hope this help with you portable antenna search.
  #3
Old 03-05-2009, 01:48 AM
W6GQ's Avatar
W6GQ W6GQ is online now
Ham Member
http://www.superantennas.com/html/yp-3_yagi_info.html
__________________
NOTICE!
QRZ REQUIRES NO PHYSICAL FITNESS PROGRAM.
EVERYONE GETS ENOUGH EXERCISE JUMPING TO CONCLUSIONS, FLYING
OFF THE HANDLE, RUNNING DOWN THE MODERATORS, KNIFING FRIENDS IN THE
BACK, DODGING RESPONSIBILITY AND PUSHING THEIR LUCK.
http://www.worldwidedx.com/
  #4
Old 03-05-2009, 02:07 AM
K4UUG's Avatar
K4UUG K4UUG is online now
Ham Member
Quote:
The Buddipole
__________________
RICK
73 !
  #5
Old 08-17-2009, 02:21 PM
GW1SXN GW1SXN is offline
Ham Member
Default SUPER ANTENNA MP-1 VERTICAL
HI,
Do you have a copy of the MP-1 Vertical review that i could have a read of ?
i understand QST had a review in Nov 2001
Patrick GW1SXN
  #6
Old 09-25-2009, 01:47 PM
KJ6AER KJ6AER is offline
Ham Member
I bought an MP-1 to try. I set it on my awning in the back yard at 8 feet. It was pretty deaf until I added one counterpoise of 33.9'. Now it works. I talked on 40 meters up 900 miles so far.
  #7
Old 09-26-2009, 02:38 AM
N3AWS N3AWS is online now
Ham Member
Default Superantennas portable Yagi
I am also curious as to the experiences others have had with this antenna. I am considering buying the whole 3 element yagi, 21' mast, and 12 volt rotor system, but would like more feedback from current users before dropping close to $1,000. I have looked at the eHam reviews, visited the company's website, downloaded the owner's manual, searched the on-line forums, etc. but still have some questions.
First, how good of quality are the components? Would they handle frequent assembly/disassembly without wearing out too quickly? If I left the antenna up for, say, three months in some light wind/rain (no ice or snow) could it handle that? Can it easily be assembled and put up by a single person?
I'm sure it will have adequate gain and F/B for my purposes, but I'm wondering about it's sturdiness, ease of assembly, etc. I am looking to use it for camping purposes and portable operations.
Any user feedback would be greatly appreciated!
Jim N3AWS
  #8
Old 09-26-2009, 10:25 PM
M0JMO M0JMO is online now
Ham Member
I have the vertical MP-1 and it works pretty well for such a small antenna.
You can put it on a balcony or ground mount it (both with suitable radials), and it works surprisingly well on the back of the car.
Seems to be well made too.
Has beryllium copper "fingers" that slide up and down the coil... Not sure if that bothers you or not? The tin foil had brigade seem to worry about it, but I generally just wash my hands after messing with the antenna.
__________________
Cheers
Josh / M0JMO
  #9
Old 10-06-2009, 09:02 PM
K6AER K6AER is online now
Ham Member
Default You won't be dissapointed
I bought the 4 element in 2003 and reviewed it at 6 months and two years later. Even though it has one more element the two antennas are very much the same.
You can look at almost 100 reviews of the three element at:
http://www.eham.net/reviews/detail/1833
4 Element Review
This is the two year plus product review of the SteppIR four element antenna. The antenna I own was the first unit built (S/N 001) and I put it up in September 2003. The performance has been flawless. My previous antenna was a TH-7DX. One of the first things I noticed was how quiet the SteppIR antenna was. The elements are not electrically connected to the boom and as a result, “P” static noise is greatly reduced.
During the last 27 months the antenna has been through dozens of ice storms, hundreds of hail storms and everyday UV radiation at the 7000 foot level here in Colorado. The fiberglass elements are still smooth and shinny and show no signs of derogation from UV radiation. Antenna strength is one of the best aspects in this design. Last year a tornado came through the ranch and the antenna did fine in the 100 MPH winds and I might add faring much better than my roof.
The antenna has been struck by lightning three times and with no damage other than a little scorching on the boom. I use MOV's at the base of the tower for the control and rotor lines and PolyPhasers for the RF cables. These are connected to a deep ground system with a measured impedance of .4 ohms. My SteppIR is mounted atop a 105 foot guyed tower and all the guy stanchions are grounded.
As you might guess, having the first antenna in the area, other hams had me installing their SteppIR's. To date I have installed 4-four elements and 2-three elements as well as two of the BIG SteppIR beam antennas that cover 40-6 meters. The kits were always complete with no missing hardware. Each one built, performed the same and to specifications. It takes about 5 hours for the four element assembly and three hours for the three element antenna. The Monster SteppIR beam takes about 14 hours to build and you need a large space for the task. Putting up the antenna is best done with a crane. You can put up the 20 meter 3 and 4 element antenna with a Jin pole.
One installation had a Crushcraft 40 meter two element beam eight feet above the 20-6 meter antenna. There was some interaction between the two and I had to reconfigure via the controller the element lengths. No problem and the antenna performed as expected.
The 20 meter 4 element antenna is made from 6061-T6 aircraft aluminum with a massive 12 by 12 by ½ mast plate. Because the antenna has most of its weight in the boom it turns about 10 degrees a second with only a Yaesu 800 series rotor. A PolyStrand truss is used to support the massive 32 foot boom. My antenna is 250 feet from the shack and the 28 volt power supply runs the stepper motors just fine. Should you have a longer run to you antennas they have a higher voltage 33 volt power supply to make up for IR losses.
At first I though the ability to change the antenna direction, electrically 180 degrees, was a neat feature but not that necessary. I was wrong. In Colorado I use 180 degree and the Bi-Directional features all the time saving much wear and tear on my rotor.
To date I have worked 234 countries on 20, about 120 countries on 10 and I might add at the bottom of the sun spot cycle. Working DX with this antenna is like hunting with a 7mm magnum. Point, shoot, bag and tag. Many times I have called CQ on what would be described as a dead band only to have DX come out of the wood work. The most heard comment is about raw signal strength. The antenna is very efficient with the side lobes down 35 dB and the beam width about 60 degrees at the 3 dB points. Even a marginal HF transceiver will be much relieved having this ahead of the front end. I run 7/8 Heliax from the station to the tower top to keep losses on 6 meters at a minimum. Needles to say at HF frequencies the losses are minimal.
Front-to-back is about 25 dB for 20-15 meters and about 17 dB for 12 and 10 meters. I have the extra elements for 6 meters giving me about 13 dBi of gain with six elements. VSWR is almost zero on all bands. If I see some, just a touch of the frequency button will eliminate the reflected power. At first I hooked the controller to automatically track the transceiver but the bandwidth of the antenna is very broad and I no longer use that feature.
I had looked at this antenna design for several years before I bought the antenna. Being able to adjust the element length seems to solve the age old problem of VSWR bandwidth vs. gain vs. front-to-back performance. I wanted to give Fluid Motion, some time to work out the bugs and mechanicals. I need not have worried. In the last two years I have talked with owners of the first units as well as new owners and they have all had nothing but praise for the factory support, design, operation and the professional manor of the crew at Fluid Motion. Their support has always been top drawer and they did not credit my credit card until after the antenna had shipped. Now for an antenna manufacture that's refreshing.
  #10
Old 10-07-2009, 01:33 PM
KB3HLK KB3HLK is online now
Ham Member
I have the MP-1 with the 80 meter add on coil and this antenna is awesome! With one counterpoise I was able to load up 80 meters with my ft 817 1.4/1 swr and reach out 500 miles on the first call. All this done mounted to a large screw driver stuck into the ground.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
