I used 12v switch power supply for radio (YAESU FT-7800R).
actually, those switch power supply is adjustable.
for example 12v you can adjustment 13.8v.
I used 15v too and then adjustment 13.8v.
I usually use the Amperemeter judgement Watt.
for example the following table.
5W = 2.5A
10W = 5A
40W = 8A
For that use, you can "expand" the voltmeter scale to make more accurate readings.
These meters are on my home-made power supply;
Notice that the voltmeter starts at 10 volts.
If you wish, you can do this by putting a 10 volt Zener diode in series with the meter; you will then have a meter that begins at 10 volts and ends at 20 volts.
You will, of course, have to change the meter scale;
