Anyone experienced problems with an 1802M that flashes frequency cutting off receive and transmit due to ? Power is not interrupted just signal. When it starts flashing ( in either scan or set) you must start scan or PTT button to clear. Happens cold, hot, moving, stopped motor on or off. Have the third unit back now to Yaesu, have had 3 new different brand antennaes, 2 separate new power cords direct to battery and problems continue. Only constant is the vehicle is the same, a late model Silverado. No stray RF, no apparent problems of any type. Totally frustrated, Thanks for any help
hi i have the exact same radio in the car, but i havent had any problems with it, im sure the unit should be replaced, its a good little rugged 2 meters. It does get a little hot, but i havent had any problems like that. have you tried the radio on a power supply in the house at all away from your suv ?
My 1802 does the same thing I have reset it at least 2 times it may go for months before it happens or it may happen daily. No set pattern, mine is in a 01 ford ranger it has done it with 2 different antennas. I guess I almost forgot about it doing it untill this posting. Good radio I get compliments about audio quality all the time. It does get warm
Yep, mine does the flashing thing, just started that. Oh, since it was new mine overheats really quick, I had to put a fan blowing across the heat sinks to make it stop overheating. Let me know what yall do to make it stop flashing !
Jake
Yes, it does. Of course, this is also true of every rig ever made.
Bill
No, it actually shuts down, without failure. It has a built in temp sensor and when it hits around 135 degrees, it shuts the transmitter off until the unit cools down. Then the unit beeps at you to tell you it is in temp alarm.
