QRZ Forums   QRZ Ad 1556
 Forum Home   QRZ Home
QRZ Ad 1994
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 2038
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Reply
Thread Tools Display Modes
  #1
Old 12-25-2007, 03:31 AM
number6's Avatar
number6 number6 is offline
QRZ Member
I have had my ticket since 1979, but have not had a shack set up
for several years, I am going to set up a new shack in a couple
of months and want to replace my old KW107 supermatch with
an auto tuner (well, I will probably move the 107 over to the
standby shelf )
Anybody care to share experiences with various units?
(I have been away from the game for a while and am just
beginning to research equipment - so not yet up to speed
on whats available.
Rig will most likely be an Icom 756 pro III - with my old 820S
sitting beside it - probably use a dipole or G5RV)
Tnx
  #2
Old 12-25-2007, 09:00 PM
W4GLM's Avatar
W4GLM W4GLM is online now
Ham Member
I use a ProIII and an Icom AH-4, what a COMBO.
The antenna is a loop and it tunes all bands, same tuner
been mounted in a plastic garbage can for 5 years (to shield
from the HOT Florida sun and it works JAM-UP.
Try one you will like it, google AH-4 and you will get many
ideas on mounting and antenna's as well.....Mac
  #3
Old 12-28-2007, 02:33 AM
number6's Avatar
QRZ Member
Very cool! This unit looks very promising.
Looking forward to getting active again.
Tnx!
  #4
Old 12-28-2007, 09:24 AM
W6PEA's Avatar
W6PEA W6PEA is offline
Ham Member
In my truck I use an Ah4 with Ic706mkiig. Works good.
__________________
Pat
73 de W6PEA
"No-Code Extra and proud of it!"
ARRL Member /ARRL VE
"When all else fails....Amatuer Radio"
Semper Fi....."Here's Looking at You Kid"
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed pharmacist"
  #5
Old 12-28-2007, 01:14 PM
W4INF's Avatar
W4INF W4INF is offline
Ham Member
I used an LDG Z-100 with Icom 718, it has a WIDE range tune, I swear it would tune a beer can dipole!
I dont need it anymore since Im running a fixed screwdriver, BUT... I still wont part with it.. I liked it so much I bought the company. HA HA!
__________________
http://rogertango.com/logbook.aspx
You might be in my log book
Best quotes of 2009
Quote:
Originally Posted by n8yx View Post
Play stupid games - win stupid prizes.
Quote:
Originally Posted by WA9UAA View Post
One of the biggest dangers of being out in the woods alone is being out in the woods alone!
  #6
Old 01-05-2008, 02:01 AM
N4KZ N4KZ is online now
XML Subscriber
I just got an MFJ-998 auto tuner. I've used various manual tuners for the past 39 years and this is my first auto tuner. It works very well. It's expensive but has a ton of features; e.g. built-in watt meter, digital readout in addition to an analog meter, rig interface so the tune button on the radio controls the tuner and an amp bypass mode.
I use the tuner with my Icom Pro3 and Ameritron ALS-600S solid-state amp. It makes for instant, no-tune QSY all over 160, 80, 40 and 30 meters -- the bands I operate with my horizontal loop antenna.
I won't get rid of my trusty 25-year-old MFJ-962 kW manual tuner but for now the auto tuner is king of the shelf, so to speak. I had just about decided to buy the MFJ-994B 600-watt auto tuner but it doesn't have an amp bypass feature which is wonderful! But the 994B sells for much less $$$. But I found a used 998 for a good price and so I made the purchase. No regrets at all.
BTW, the fit and finish on the MFJ-998 is excellent. I like it.
73, N4KZ
  #7
Old 01-05-2008, 04:42 AM
N4BFD's Avatar
N4BFD N4BFD is offline
Ham Member
I have the baby version of the above, a MFJ-993B, has foward and reverse watt/SWR meter, and a digital meter with cap and inductance values, frequency counter, fwd and reverse power and SWR. The meter is peak reading, has a built in balun for ladder line, and two antenna inputs.
Has a few zillion memorys for tuner settings for up to 4 antennas I think, once you tune at a certain frequency then go back to it later, as soon as you transmit the tuner goes "CLUNK" and your tuned instantly. I used to have to spend time fiddling around tuning when jumping bands, no longer... I switch bands, and in split second I am tuned.
I think many of the auto tuners out there do that these days. Anyway, the two meters on the MFJ come in handy, I like seeing actual numbers for my SWR and power, never thought that would be a big deal to me till I started using it. It cost around 230 dollars from R&L I think. One of the few MFJ tuners that eham reviewers like.
  #8
Old 01-05-2008, 12:18 PM
PA5COR's Avatar
PA5COR PA5COR is online now
Ham Member
I have the MFJ 993-B tuner as well, and must say it works just fine..
True to the MFJ name the lightbulb for the analog power/swr meter burned out in 2 days, as did it with my friends tuner.
Replaced it with an better one, added an resistor wich will add in keeping it burning an lot longer.
For the rest it does work as advertised.
Cor
__________________
Licensed since 1977
  #9
Old 01-05-2008, 01:29 PM
AB8XA's Avatar
AB8XA AB8XA is online now
XML Subscriber
The Icom tuner is highly popular for several reasons. #I like it because it addresses the mismatch problem out between the antenna and feed line, not in the shack. #Find out more about it and other Icom tuners by joining the Yahoo! IcomTuner Group.
__________________
73 de Moe
Member: ARRL, DARA, UVARC
FISTS #13020, PODXS 070 #977
  #10
Old 01-07-2008, 05:05 AM
KD6WAG
Guest
Posts: n/a
For all of my portable work with an 857d and just running 100 watts, I use an LDG AT-200PRO. I love it. It's simple to use and generally gives me a 1:1 on everything from a G5RV, Hamsticks, Buddiepoles etc...
I plan on testing it on a random wire here in the near future. But... when I finally get around to buying that Tokyo Hi-power that pushes a kw, it's going to be a "Palstar" all the way.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
