QRZ Forums   QRZ Ad 2058
 Forum Home   QRZ Home
QRZ Ad 1496
QRZ Ad 1997
QRZ Ad 1991
QRZ Ad 1440
QRZ Ad 55
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
  #1
Old 12-20-2007, 04:54 PM
W0BKR's Avatar
W0BKR W0BKR is online now
Ham Member
I recently acquired a 655B EQ unit to run my audio thru now and then. Never did work quite right. I contacted MFJ and was told to send it in. Found out 2 pots or caps, forget which, were installed incorrectly and another was flip flopped (not sure what that means), but they corrected it and sent it back.
Kinda bothers me with their QA. Ten Tec is much the same though so can't always just say MFJ.
__________________
Chris
ARRL Life Member
#1 DXCC
20 WPM Extra (It ain't that hard!)
  #2
Old 12-21-2007, 10:18 AM
W1GUH's Avatar
W1GUH W1GUH is online now
Premium Subscriber
Another MFJ "semi-kit." It's been a recurrent theme here about their quality control. But if you look at the warrantee, it specifically says it's ok to fix it yourself, you won't void it. So if you get something from MFJ and it looks like there's something wrong, go ahead and dig into it to find the problem. If it's a bad component, MFJ will replace it.
I recently got their balanced balanced antenna tuner & it had a bad solder joint that I had to fix.
  #3
Old 01-04-2008, 09:28 PM
W0BKR's Avatar
Ham Member
I sent it back to them, it was mis-wired but they corrected it. Still sounds like a bit of distortion in the monitored audio. I may never use it again.
May end up sitting on a shelf.
__________________
Chris
ARRL Life Member
#1 DXCC
  #4
Old 01-14-2008, 02:38 AM
ae5eh
Guest
Posts: n/a
Martin (mighty) F (fine) Jun (junk)
  #5
Old 02-28-2008, 11:38 AM
K3ROJ K3ROJ is online now
Premium Subscriber
Default Mfj-655b
Same thing here. You would think MFJ would tighten up and check each piece of gear before they ship it. It is so much trouble repacking and shipping things back to them that it is worthwile to at least troubleshoot it yourself. I was lucky finding an unsoldered joint on one of the pots which was a quick fix. Now it works like a champ and use it with Heils Heritage microphone since the 655B excepts a balanced 600 ohm microphone.
  #6
Old 02-28-2008, 10:22 PM
W2KG's Avatar
W2KG W2KG is online now
Ham Member
Question Haven't had a problem yet!
In thirty years or so of operation, I've bought several items from MFJ and I've apparently been very fortunate, because I've never had a problem with any of them. On the other hand, I bought a brand new keyer (KR-60A, what a beauty!) from Ten Tec years back that I had to repair and from Dentron (may they rest in peace) an MLA-1200 linear amplifier with the power switch miswired. I fixed that, too. I guess it's the luck of the draw. However, I heartily agree (based on the volume of complaints I've read) that MFJ should really tighten up their QA. Of course, if the manufacture is subcontracted off shore, then it's a bit more of a challenge.
__________________
73 de W2KG Tom
Proudly generating TVI for over 30 happy years! (Antiquity is no guarantee of quality.)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
