QRZ Forums   QRZ Ad 1989
 Forum Home   QRZ Home
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 1997
QRZ Ad 1994
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Reply
Thread Tools Display Modes
  #1
Old 09-22-2007, 01:31 AM
N9NY N9NY is offline
Ham Member
Had an Alpha and sold it but want to get a no tune amp for harder to break pile ups and was considering the ALS 600 no tune unit.
I am running a TS 870 to a Hygain Hy-tower. SWR on that tower can very and I was curious/concerned how tempermental this amp is with SWR's in the 1.7 to 1 or slightly higher?
I would also appreciiate owner comments on this unit...pros and cons
  #2
Old 09-24-2007, 03:28 PM
K5RCD's Avatar
K5RCD K5RCD is offline
Premium Subscriber
I don't have one - yet. I have been considering buying one. Maybe this year Santa will bring me one if I am a good boy. I have spoken with several owners on the air and all have reported excellent results with this amp, BUT all have said the unit goes into auto by-pass fail safe mode at between 1.8 and 2.0 SWR. If the auto tuner on your TS 870 can't reduce SWR below that, then just about any outboard tuner that can handle 600 watts or so should work OK. If you buy one, please give us a report on this board letting us know how it works for you.
__________________
73, Randy
K5RCD
South Texas.
ARRL VE
http://www.k5rcd.org
  #3
Old 09-25-2007, 11:49 PM
Ham Member
Found out that there is a two to three month wait for these units.
  #4
Old 09-27-2007, 01:08 PM
K2MMO K2MMO is online now
Ham Member
I have the ALS 600S (Smaller power supply) and it is great .....I do not have an SWR problem with my antenna
but #on some bands I do get as high as 1.7 SWR at certain points in the bands...as the antenna is direct and not through the antenna tuner...(if the SWR got to high iI would switch to the Tuner)...and I get great results......Easy to tune, easy band switching....have not used it much...(used it on 20 and 40 Meters) but when I have loved it.....Definitely recommend it
  #5
Old 09-27-2007, 01:09 PM
Ham Member
AES has them in stock
  #6
Old 10-19-2007, 03:53 AM
WZ0O's Avatar
WZ0O WZ0O is online now
Premium Subscriber
Bought a used one that had relay troubles. Got that fixed and love the amp. SWR is tight not over 1.5 -1.7 but if you start out with the drive turned down a little you should have no trouble. An auto tuner is next for me.The amp has gotten good reports on the air and the no tune feature is great. Check your line voltage and run it on a feed other then your radio. The amp does not like LoW line voltage.
__________________
Good Judgement comes from experience.
Experience comes from Bad Judgement.
  #7
Old 10-23-2007, 12:07 PM
WZ0O's Avatar
Premium Subscriber
Update
The trouble returned. SWR up and down fault light comming on and poor reception. So I went back to work and found the trouble 2 cold solder joints. Both on the small coax. After re soldering all troubles are gone. 90 watts in 500 out, 100 in 700 out. Reception now up to par with the amp out of the system. If you have trouble check them%$#^% solder joints. Too bad quality control is so poor cause this is a great amp.
__________________
  #8
Old 10-25-2007, 06:52 PM
w3scm w3scm is offline
Ham Member
Quote:
Originally Posted by [b
Quote[/b] (k5rcd @ Sep. 23 2007,09:28)]the unit goes into auto by-pass fail safe mode at between 1.8 and 2.0 SWR. If the auto tuner on your TS 870 can't reduce SWR below that,
Huh?
__________________
73, Scott W3SCM
"Idealist: one who, upon noting that a rose smells better than a cabbage, concludes that it will also make a better soup." -Menken
Zen proverb: "In the beginner's mind, there are many possibilities. #In the expert's mind, there are only a few."
  #9
Old 10-25-2007, 10:05 PM
K5RCD's Avatar
Premium Subscriber
Quote[/b] (w3scm @ Oct. 25 2007,13:52)]
Huh?
Scott:
What do you fail to understand ?
"all have said the unit goes into auto by-pass fail safe mode at between 1.8 and 2.0 SWR. If the auto tuner on your TS 870 can't reduce SWR below that, then just about any outboard tuner that can handle 600 watts or so should work OK." #
__________________
73, Randy
K5RCD
South Texas.
ARRL VE
  #10
Old 10-26-2007, 01:55 PM
Ham Member
Replied via private message.
__________________
73, Scott W3SCM
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
