Hi All,
with the Icom 7000 which antenna tuner do you all use. Because of the better half I will be using a wire antenna and would like the tuner in the shack. I figure I can run about 140 feet of wire if that make any difference.
I also have an Icom 7000 and was wondering the same question. I see that Icom have the Icom AT180 which buy the way is quite expensive down here in VK land. I have also seen that LDG make an LDG AT7000 suited for the Icom 7000. It costs much less than the Icom AT180, is much smaller and has a lot more memories too. It also comes with the coax patch lead and lead to go from the Icom 7000 to the tuner. Everything you need, just plug in and play. I am currently looking at them both and will make a decision soon.
I used the LDG RT-11 Remote Tuner with my 7000. It did work just fine. However the RT-11 is no longer made, but don't think you can go wrong with any version of an LDG tuner. They do interrface nicely with the radio.
__________________
Bill, W0LPQ
Collins Avionics Field Service, Retired
I use an IC7000 aboard a large ship. I use a 35 foot whip and currantly the ah4 coupler. its always best to use a coupler at the load (the ant for xmit). Have had excelent results with this set up. have also used an SGC smart tuner which I prefer. It was just easier for me to get the ah4 in singapore. If I had my choice I would have gone with the SGC. No problems with the ah4 however. It would not tune the ant on 160.. the SGC would.. no problem for me but it could be an issue for others. the
SGC had a more heavy duty apearance but that was simply esthetics..
Lee it is refreshing to see someone else with the same thoughts .. tuner at the load. We do that with aircraft and still some people cannot understand why ..
That is why Collins made pressurized couplers..!
__________________
Bill, W0LPQ
