QRZ Forums   QRZ Ad 1267
 Forum Home   QRZ Home
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 1997
QRZ Ad 1991
QRZ Ad 1440
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Reply
Thread Tools Display Modes
  #1
Old 08-29-2007, 04:41 PM
W3XAF W3XAF is offline
Ham Member
Thumbs up
I purchased an MFJ-1775 rotatable dipole antenna and installed it on top of a Ham IV Rotor.
The dipole was very easy to put together and MFJ provided many spare parts with the MFJ-1775 kit.
The dipole consists of one 14-foot long aluminum element (tube) which has two coil assemblies attached to each end of the aluminum tube. #Each coil assembly consists of four coils, one coil each for 10, 15, 20 & 40 meters. #Connected to each coil is a metal ring which has four graphite spokes inserted into holes in the ring.
In order to create a resonant frequency on each band, one has to painstakingly cut each graphite spoke using an MFJ-259B SWR Analyzer until the resonant frequency is achieved. #That task took me about three hours.
After I hoisted the antenna into my Ham IV Rotor, and connected the RG-213 Coax to the antenna balun, I rechecked all the resonant frequencies and they had all changed. #This might have been due to the fact that I used five plastic covered steel guy wires to secure my antenna mast to the ground beneath.
I finally replaced all my guy wires with 3/8" Dacron rope and then had to re-cut the antenna spokes to the required resonant frequencies for each band. #No easy task standing on a sloping roof 50 feet above the ground.
Furthermore, I found it necessary to order more 30"-long spokes from MFJ in order to achieve the 40 Meter resonant frequency I needed.
I then ran into a major problem. #When I applied power to my antenna and tuned up using my FT-1000MP Mark IV Transceiver, AL-80B Amplifier and MFJ 989D Tuner, I found that the resonant frequencies for each band were not the same as those I had established with my MFJ-259B SWR Analyzer. #Therefore, I had to go back up on my roof and re-cut or lengthen the graphite spokes accordingly. #This task took many days!!!
The only other problem I have experienced now that the antenna spokes are all cut for the resonant frequencies that I want to operate on, is that when I use voice modulation my SWR varies between 1:1 and 1:4 depending on how long I speak into the microphone. #The longer I speak into my microphone, the higher the SWR goes. This problem may be the result of my balun overheating?
  #2
Old 11-26-2007, 04:49 AM
Ham Member
Thumbs down
It's been over a year now that I constructed & installed my MFJ-1775 Rotatable Dipole. So far, I've burned up three different coil assemblies.
Hy-Gain, who now has control over all MFJ antennas, has sent me new coil assemblies because my antenna was still under warranty.
The problem seems to be with the 20-Meter coil. For some reason the fiberglass tube that the coil is wrapped on will eventually burn up and this leaves a rather large hole in the tube. After the hole is formed, my 20-Meter SWR shoots up and I can't use the 20-Meter band any longer.
Hy-Gain thinks that the problem is metallic impurities in the fiberglass tubes.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
