QRZ Forums
 Forum Home   QRZ Home
QRZ Ad 2038
QRZ Ad 1994
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
  #1
Old 11-10-2009, 10:42 AM
KA5S KA5S is online now
Subscriber
Default Combining VHF Amplifiers
Elsewhere in the Forums an Amateur asks how to combine two 300 watt 2m amplifiers. The answer is the Wilkinson Hybrid. This page, while labelled 6m, is a excellent tutorial how to build one. And it only needs some 70 ohm coax and VHF-capable 100 ohm resistors.
Cortland
KA5S
  #2
Old 11-14-2009, 03:32 PM
VK6ZGO VK6ZGO is online now
Ham Member
Quote:
Cortland
KA5S
Make sure both Amplifiers are quite close in output power level,as any
unbalanced power is used to make those 100 ohm resistors hot!
73 VK6ZGO
  #3
Old 11-15-2009, 01:07 AM
WA7PRC WA7PRC is offline
Ham Member
Default Re: Combining VHF Amplifiers
Cortland
KA5S
73 VK6ZGO
My current gig is with the largest OEM of sealed CO2 lasers, where we drive them with RF power. The laser tubes are about 10% efficient and produce up to about 250W of laser power. Our RF drivers then, have to produce kilowatts of RF and often use Wilkinson combiners. If, in a two-driver system, one driver stops working, the resistor has to 'suck up' half the other driver's power. The resistor is sized to do this. There are various manufacturers of flange-mount RF resistors up to about 800W. They can be found at the RF Cafe.
In a previous life in FM broadcast, we had two 8kw transmitters combined, for 16kw to the antenna. The hybrid was an impressive setup! One night, in the dead of Winter, a screen bypass capacitor in the socket of one of the driver tubes shorted, effectively shutting-down that unit. When we arrived to the unheated shack, it was very warm inside. And, the reject load (an air-cooled 4kw unit) was working hard!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
