Anyone know where I can get a Thermal Coupler for a cushman CE-6A Crystal Oscillator?
All I can find on it, it says Thermal Coupler 141 Degree C. Any help would be appreciated.
Got to looking closer it says Thermal Cutout.
KA0JON - David
How do you know it's bad? Is it a resettable type? These are very seldom the problem. It looks like your thermostat got hung, which in turn caused the cutout to trip.
Eric
__________________
That's not right. It's not even wrong.
-----Wofgang Pauli-----
Eric
Yes this is the resettable type. It took 1 of the diodes of fullwave bridge. +output of bridge goes to thermal cutout in series with the heating coil wrapped around the xtal. From what I'ved traced in the circuit 120 vac comes into fullwave bridge and then threw the thermal cut out to the coil. Other side of coil goes to minus side of bridge.
David
I don't know the intimate details of the oven control of a Cushman, but I do know they're pretty sophisticated. There's probably an integral cycle temperature controller on the A.C. side of the bridge, and SOMEsort of feedback circuit. Do you have the manual for it?
Eric
__________________
Eric
Somewhere here my shack, I found my Cushman CE-3 Manual, thought I had them both together at one time.
Time to go digging in shack.
