ad: CommRadio-1
Results 1 to 10 of 21
Thread: D-104
    Aug 2001
    Duncan, BC Canada
    Unscrew bottom cover... check the connections... I can key the radio up. ... BUT it won't pass the audio. I futher checked... took the relay out of the tube... Oh my.
    Took my 30 mins to fit it back in place
    Ok. So much for making a foot switch for it.
    I was trying to get my foot switch to be used as a ptt switch for my d-104
    Ladies love outlaws!!! - Waylon Jennings
    So let it be written.... So let it be done!!!
    "Out of the eater came something to eat.... Out of the strong came something sweet." - Samson
  2. Default
    Huh? What is the issue?
    The only easy day was yesterday!
    www.k5uss.com
    What did he say?
    Aug 2003
    W6ECE -- he said he has GAS!!!
    ... ( sarcasm mode ) ...a foot switch for a microphone ? Are you THAT busy ( no I did not say lazy ) ?
    Just take the footswitch off the 2 kw linear amplifier, and use it, or make one from scratch using available parts and accessories.
    How about a footswitch from an old sewing machine ?
    How about a footswitch from an old car that had the HI/LOW headlight control on the left corner of the driver side floorboard ? Remember them ? Man you ARE old !!!I also remember them...so I am old, too.
    Just some sarcasm and a couple of ideas for modifications for all those who read this .
    GOOD LUCK
    AI4EP (Robert)
    God loves you .
    Be as nice as you can to others.
    I type real slow for those of you who can not read fast.
    ...or a extra cw key from back in your cb days ...
    God loves you .
    Sep 2002
    Fargo ND
    Woo HOO!
    Mark
    Jun 2005
    Tucson, AZ
    Quote Originally Posted by [b
    Quote[/b] (ai4ep @ May 13 2006,03:49)] ...How about a footswitch from an old car that had the HI/LOW headlight control on the left corner of the driver side floorboard ? #Remember them ? # Man you ARE old !!!I also remember them...so I am old, too.
    GOOD LUCK
    AI4EP (Robert) # #
    Now if you really need to switch a BIG load, try the footswitch GM used to crank the starter on a '53 Chevy Pickup!
    Heel on the gas peddle, toe on the starter switch; crank the one-lung six-popper while you give it a little gas.
    That switch had a pair of really big contacts since the starter in a 6V system drew beaucoup current.
    How's THAT for old?
    73 DE KAØGKT/7
    --Steve
    73 DE KAØGKT/7
    --Steve
    Jul 2005
    Cincinnati, Ohio, US
    ai4ep:
    Quote[/b] ]How about a footswitch from an old car that had the HI/LOW headlight control on the left corner of the driver side floorboard ? Remember them ? Man you ARE old !!!I also remember them...so I am old, too.
    I still have one. I'm... older than the car it's in anyhow.
    The dingdong formerly known as kd8bsr
    Or just buy one. You can get the Heil foot switch for about $35 new, and it's *expensive*.
    I've been thinking about taking my D-104 apart. Still works fine, but the PTT doesn't have the "spring" it once had. Maybe I'll leave it alone...
    73, Rob
