ad: w5yi
Results 1 to 6 of 6
Thread: PK-232 Software??
    Apr 2005
    Kingsburg, CA
    Help...my old PK-232MBX and PAKRATT II software will not function with my new Pentium 3 computer. I've been advised to either locate an old DOS computer...or change my software. Any ideas?? I keep hearing that there are "tons" of free RTTY/CW/ASCII programs "out there", but where??? So...either another bit of software or that old 8088/286/386 computer sitting in your Central; California garage?? Thanks in advance
    Chuck
    kj6do@accessbee.com
    Thumbs up
    Chuck -
    As you may know, support for PakRatt for DOS and Windows support ended in the 1990s (software never transitioned past the Win16 code set).
    http://www.timewave.com/PakRatt.html
    Timewave switched to PK-Term for Windows software (Windows 95/98/NT/2000/XP support) by CSS in December 1998. #This is still the currently supported software suite. #PK-232MBX firmware version 7.0 or later may be required to work with PK-Term for Windows. #CSS web page:
    http://www.cssincorp.com/prod-pkterm.htm
    PK232 Upgrade Guide (Timewave, Corp.)
    http://www.timewave.com/PK232UgradeGuide.html
    CSS Free TNC Wizard for PC port location
    http://www.cssincorp.com/wizard/
    As for the "free software",
    YES there are a large number shareware programs available - BUT largely for usage with a personal computer (PC) sound card (which has DSP embedded inside). #
    You can build a sound card interface or ADD the PSK/Sound card interface kit
    http://www.timewave.com/PK232PSKupg.html
    PSK Sound Card Upgrade Data Sheet
    http://www.timewave.com/Acrobat/PK232PSKupgDS.pdf
    PSK Sound Card Upgrade Kit - Manual (Adobe Acrobat)
    http://www.timewave.com/Acrobat/A.06219.pdf
    At $69.95 this is less expensive than a WMR Rigrunner.
    My recomendation
    FORGET the old PC hunt - unless you have one (FREE) that you just desire to operate in dedicated mode. #If you have to spend $$ to acquire one -- spend that money on software or the sound card upgrade to your PK-232.
    The "FREE software" or shareware that you desire is going to be written for Windows (98 at the least and eventually only W2K and XP - which are far more stable OS) or Linux. #Don't expect the shareware software writer to spend time supporting old operating systems - no $ market.
    At a minimum consider the Timewave PSK Sound Card upgrade, whether you desire to also purchase PK-Term is really a choice of what digital modes you use with your PK-232.
    May 2003
    Point Pleasant Beach NJ
    Hi chuck and readers,
    While W9GB gave some good advice I have something to add. If your software won't run in the DOS window try upgrading your OS to Win XP w/SP2 which doesn't even use a window, simply emulates DOS and some MAC and others very well. Not only that but it emulates old Windows very well too, I run a terminal program from V3.11 and some other stuff without a hitch.
    I don't suffer from insanity, I enjoy every minute of it.
    73 de Warren KB2VXA
    A few web sites that you should look at:
    Ernie Mills, W2MU Digital Amateur Radio
    http://www.qsl.net/wm2u/
    PC AVTech - Sound Cards Compared and Tested
    Avoid poor performing cards - at any price
    http://www.pcavtech.com/soundcards/compare/index.htm
    Just PSK31
    http://www.qsl.net/wm2u/psk31.html
    HamScope version 1.55
    http://www.qsl.net/hamscope/HamScope.html
    HamScope is a multi-mode communications interface for amateur radio that supports:
    PSK31 (BPSK and QPSK, see PSK31 Home Page )
    RTTY (HamScope uses Makoto Mori's MMTTY Engine)
    ASCII (both 7 bit and 8 bit protocols using MMTTY)
    MFSK16 (see MFSK16 Home Page )
    PACKET (HamScope uses George Rossopoulos' AGWPE Engine)
    CW
    Ralph Milnes KC2RLM - Soundcard packet
    http://www.patmedia.net/ralphmilnes/soundcardpacket/
    KK7UQ Digital Radio
    http://kk7uq.hfradio.org/index.htm
    Try this one for the PK-232 www.nfbnet.org download the file PW210.zip and go from there. My old PK-232 v1.06 DOS software runs great with WIN XP Pro.
    Jun 2003
    Fall City, WA
    Where on that site is it?
    I'll add that the Packratt-88 software runs under ME with little problem as well..
