ad: M2Ant-1
Amateur Radio Superstation - K3LR
Discussion in 'Amateur Radio News' started by AA7BQ, Jul 30, 2014.
  1. AA7BQ
    AA7BQ QRZ Founder QRZ HQ Staff QRZ Page
    I recently had an opportunity to visit the station of Tim Duffy, K3LR of West Middlesex, PA. Tim has been a ham since 1972 and in 1987 he bought an 11 acre, 1860's farm property and immediately started setting up his dream station. Today, 27 years later, it has become that and much more. Simply stated, the K3LR station is one of the number one Multi/Multi contest DX stations on the planet. Tim engineered and built the entire station and its massive 11 acre antenna farm of 13 towers, including its Yagi's, directional arrays, and switching systems that give it capabilities that are seldom seen in the amateur world.
    The photo above shows a partial picture of the layout. The operating positions are in the basement of the old farm house (the white building) and nearly every antenna is fed with 1 5/8 inch hardline in uninterrupted runs that span as much as 1500 feet from the antennas to the shack. Why hard line? Although very expensive new, most of the line Tim used was obtained used as surplus from cellular or two way antenna companies at a fraction of its original cost. The towers are also from cellular and broadcast surplus sales.
    One of Tim's crown jewels is the 20 meter stacked Yagi array. Situated on one of the tall towers, it includes 4 full sized, custom designed 20 meter Yagi's that Tim built himself. Spaced exactly one wavelength apart on the tower, they can be operated either individually or in various phased combinations. Each antenna has its own separate ring rotator. When all 4 are fed in phase and pointed towards Europe, signal reports are 5/9+ on a bad day . With a total of 24 elements in phase, the array sounds like a 1500 watt linear, even when running only 100 watts.
    Tim has multiple Yagi's on all bands from 40 through 6 meters however most of his favorite and challenging operating is done on the lower bands with vertical arrays.
    Looking up from the ground you get an idea of just how much is going on up there. this could be the 40 meter tower, or perhaps the 20, I couldn't keep track of them all.
    This is the base of one of the towers showing all of the switching and control circuits.
    This picture shows how the scale of the tower distorts your perspective. At the very top is a full sized, 102 foot, 80 meter dipole. Below that is a 20 meter monoband Yagi. It's worth noting that all of the antennas are monobanders and that there are multiple choices for every band. SWR is never a problem as each antenna is specifically tuned to provide less than 1.2:1 across the design operating band.
    At first glance, this looks like a tower that is under construction. What it is, however, is a full sized 160M vertical Yagi antenna. The center tower is the radiator (driven element) and it is surrounded by 4 vertical "T" wires that can be switched in and out to provide reflectors and directors in 4 directions.
    This picture was altered to highlight the vertical T-wires of the 160 meter vertical Yagi. Note the shorting relay boxes at the base of each wire, used to direct the beam.
    Base of the 160M vertical. Note the clear insulators below the supports, and the 1 5/8 Hardline feed. The radial system is also quite massive and uses over 20,000 feet of tinned copper wire that is soldered to the main connector ring, shown above.
    This is a 20 meter directional receiving array. Tim has arrays like this for all bands, 80-10 meters. Each antenna consists of a 1/4 wave vertical, spaced 1/4 wave apart.
    Let's have a look inside the shack. First, however, you should know what a multi/multi station is used for. A multi/multi station is a Multi-operator / Multi-radio contest station. In the large DX contests, these large stations are in a separate category. Four times per year, Tim invites a dozen or so of the best contest operators from around the world to join him in his shack to work the contests and have fun. The K3LR station has an impressive track record of success, having won (#1 in the USA) an impressive number of DX contests in the multi multi category, especially since 2004. Tim has hosted over 100 different contest operators during the 22 years they have competed in Multi Multi.
    This is an excerpt from a chart showing just how winning K3LR has been in the ARRL SSB contest.
    Tim, in the shack showing the operating positions. Each operating position works just a single band.
    Tim, K3LR and Fred, AA7BQ standing before a few of K3LR's grand prize trophies.
    Two of the many single band 1500 watt amplifiers that are used at K3LR using a single 8877 tube. No band switch, just pure legal power on a given band.
    Another pair of amps, as well as a matrix switch used to configure the receiving antennas. Above to the right is where some of the hardline enters the shack.
    A typical operating position. Note the four rotators for a stack of antennas. Every position has either an IC-7800 or an IC-7700 radio. In all, there are about 10 IC-7800's in the shack, including a hot spare. While heavily recognized by ICOM, there is no corporate sponsorship whatsoever. Tim buys nearly all of his gear used, at bargain prices.
    Tim at the 20 meter position. We fired it up and were able to work a station in Sweden right away. The operator on the other end refused to believe that we were "barefoot", running 100 watts. You can't understate the power of a 24 element array!
    There are also some great videos including a drone fly-over that is impressive. Check out:
    [video=youtube;OMzdTQzJjSc]https://www.youtube.com/watch?v=OMzdTQzJjSc[/video]
    K3LR Icom video
    http://www.youtube.com/watch?v=wlXu7Q3h8RI
    http://www.youtube.com/watch?v=jo2mCNJdvdk
    K3LR Fly By videos
    http://www.youtube.com/watch?v=OMzdTQzJjSc
    http://www.youtube.com/watch?v=kimSQsEKqGE
    K3LR QRP QSO
    http://www.youtube.com/watch?v=6Tk4kz5OeIE
    More photos in larger formats are available on my Google+ page here
    Also, for the detailed (accurate) specs of the station and it's history, see http://www.k3lr.com
    K8LJM, WM7C and (deleted member) like this.
  2. KC9EOQ
    KC9EOQ Premium Subscriber QRZ Page
    Nice tour of K3LR's shack. All I can say is, Wow!
  3. KB3UWC
    KB3UWC Ham Member QRZ Page
    A few months back, I was lucky to get a tour of Tim's Station, with the guy's from the K3MJW Skyview radio society. Wow is right.
    Steve KB3UWC
  4. KB3PHL
    KB3PHL XML Subscriber QRZ Page
    I"ll ditto that, WOW!
  5. N0IRS
    N0IRS Ham Member QRZ Page
    Nice job Fred. Good photos and like how well you documented the various antenna installations and station positions. I have seen alot about this wonderland through Ham Nation and various videos on YouTube. K3LR's station is a show of technical achievement and a person's fulfillment of a dream. When we stop dreaming... well you know how it goes. We may never get to this level, but we will ....reach our own dream one day!
  6. WW7F
    WW7F Guest
    IS that what ham radio is like in the afterlife, cause that station would be heaven to operate:)
    Great tour Fred,I wish you all 73,Michelle:)
  7. WJ4U
    WJ4U Subscriber QRZ Page
    Amazing. Thanks for the tour!
  8. N8CR
    N8CR Ham Member QRZ Page
    I saw this from I-80 this last March on a quick out and back to NYC. Told the XYL, now that's an antenna farm. Her response, "that's nice dear, keep your eyes on the road."
  9. KC0W
    KC0W Premium Subscriber QRZ Page
    Amateur radio enthusiasts UNITE!!! :)
    Tom KCØW
  10. KG0MN
    KG0MN Ham Member QRZ Page
    I could not even afford the hardline. It must be nice to have that much money to toss at a hobby.
  11. W6OGC
    W6OGC Ham Member QRZ Page
    Didn't you know that it's not just a hobby but a way of life?
  12. N5USS
    N5USS Ham Member QRZ Page
    I saw Tim last Friday and Saturday in OKC at our hamfest. Heckuva nice guy. Tim lived in OKC for a good number of years due to his work but just moved back to PA last year to run DX Engineering which brings him back to his home superstation.
    Funny thing is, with the K3LR superstation back in PA, all he had at his OKC home was a simple Buddipole. Tim was always willing to stop and help any ham with any problem, even came to my home to advise me on an antenna problem. He even built me a simple ground plane antenna one day. You can't find a nicer guy anywhere.
    By by the way, Tim has the best way to attach PL 259's, see his videos and written instructions.
    And yes, Tim has told me before that he buys used radios, and he is a "big knob" guy and doesn't care for physically small radios.
  13. N4EYZ
    N4EYZ Ham Member QRZ Page
    Impressive! Someone commented that it must be nice to be able to put all that into the hobby. Well.......it is nice to be able to do that and I'm glad when someone has been blessed enough to be able to do what they really enjoy. Whether your love is amateur radio, flying, motorcycles or whatever.......just do it to the best of your ability and have fun. As long as one's family is loved and cared for................have fun doing whatever you love!!
    N9MET likes this.
  14. K2HAT
    Yes WOW. Impressive. Thanks for sharing, really nice presentation.
    I can not imagine the Time to get that all together, not even thinking about the money.
    That must be nice to have the available Land to do that too.
    I am stuck here in a 26 foot wide city lot,
    at least it is a little over 100ft deep so it does have room for a G5RV. :)
  15. N7AIG
    N7AIG Ham Member QRZ Page
    Holy Cow! Apart from the initial outlay, I can't imagine having the funds to support the maintenance costs on this! Sheesh! Must be really nice to see a dream fulfilled like that! 73's and more power to you!!!
    = de Dave, N7AIG
