Results 1 to 3 of 3
Thread: ICOM IC-730 HOW MUCH?
    May 2004
    Cumberland, MD
    I am bidding on an Icom 730. Any opinions on how high to go? Any reviews from current users/owners. How would you feel about this for a first hf for a new General.
    May 2002
    Hopkinsville KY
    The 730 is a pretty nice rig and has a quite good receiver in terms of dynamic range and is on par with many of the radios available today.. However... it is about 20 years old.
    I have seen them go as low as $225 and as high as $400+ with the power supply and the CW filter. One thing to keep in mind is that for $400 you can get a much newer radio like the Alinco DX-70 series,(a vastly underrated radio and maybe the best bargain out there) an early IC-706 or 718 or possibly Yaesu 840. I personally would not bid over $300 for a 730.
    George
    K3UD
    K3UD
    (EX- Novice - Tech - General - Advanced)
    SKCC 879 - SPAR - ARRL - W5YI VE
    [URL]http://www.members.hopkinsville.net/geomac/[/URL]
    [SIZE=1][B](Western Radio Website)[/B][/SIZE]
    [URL]http://www.trailoftears.org[/URL]
    [SIZE=1][B](Cherokee Trail Of Tears Website)
    [/B][/SIZE][URL="http://www.hopkinsvillenostalgia.com/"]http://www.hopkinsvillenostalgia.com[/URL]
    [SIZE=1][B](Website for my region in western KY)[/B][/SIZE]
    Hopkinsville KY, home of the the total eclipse of the sun 8/21/2017
    The early Icom (730)doesn't have a preamp stage in it. The preamp is in the HM-7 handmike so you are limited to the hand mike. I have a 730 and I am useing a iCM by Heil on mine (compressor on and mike gain at 3:00) and works just fine. I like mine and I have been at this for almost 30 years but you can do better then the 730. The 730 is still going for 200.00 -375.00.
    If you want use an antenna (auto) tuner with it (like Icom AT-150) make sure the radio has the EX-202 modual in it. That is needed for Bandswitching and 8.0 vdc and 13.8 vdc to make the AT-150 work. LDG has a tuner that just needs 13.8 vdc and will work fine for a 100 watt rig.
    The 730 has the W.A.R.C. bands in (10/17/12 meters),a good receiver and easy to use.
    Hope this helps you
    W0DON
    Don
