ad: jbsims
Results 1 to 4 of 4
Thread: Tone board for Kenwood TR-7600
    Jul 2011
    North Carolina
    Default Tone board for Kenwood TR-7600
    Today I picked up a Kenwood TR-7600 2 M FM transceiver at a hamfest. Works good, except it does not have a tone board for repeater access.
    Does anyone know what tone board I need for this radio, and where can i get one?
    Thanks in advance.
    The Kenwood TR-7600 is a digitally synthesized high performance, 2 meter mobile transceiver.
    It features a four digit LED frequency display with memory.
    Transmit power may be set for 1 or 10 watts. Frequency range is 144 - 147.995 MHz.
    6.3 x 2.375 x 9.2 inches 4 lbs. Requires 13.8 VDC at 3 amps.
    Kenwood TR-7600 / TR-7625 Operating Manual
    http://boxspringsonline.com/kenwood/...anual/download
    There are ONLY Two Commercial After-Market suppliers for CTCSS add-on boards.
    Piexx and Com-Spec. Purchase from your favorite amateur radio dealer OR directly.
    Piexx Tone Boards
    Hillsboro, NH
    http://www.piexx.com/index.php?main_...ort=20a&page=1
    CONTACT Piexx for specific board and installation details
    Com-Spec SS-64 CTCSS Encoder Board
    Orange, CA
    http://www.com-spec.com/ss64.htm
    SS-64 Instructions
    http://www.com-spec.com/insheet/ss64inst.pdf
    SPECIFIC Instructions for installing Com-Spec SS-64 into your Kenwood TR-7600
    http://www.com-spec.com/insheet/tr7600.pdf
    Jul 2011
    North Carolina
    1003953_3528965000450_461197313_n.jpg1455914_3528965240456_1487892650_n.jpg1465203_3528964800445_392735284_n.jpg1471368_3528964600440_1318320294_n.jpg
    Thanks W9GB. Just got my board in today. Installed it and so far it works, although for some reason there's a repeater 20 miles from me, that on 10 w. all you hear is a buzz when I key up, but when I drop it to 1 watt I'm clear as a bell....but the repeater 10 miles from me is fine on 1 or 10 watts. I tried adjusting the little pot on the radio but to no aval. Anyone know why this is?
    Jan 2009
    I reside outside of Elgin, Illinois in an unincorporated rural sub-division. 925' ASL
    Dave,
    Considering where you're located / stationed, I'd try to find the electronics shop where they might have a Service Monitor to set the CTCSS Subaudible Tone to +/- 750 Hz Deviation Level. That tone might be over Deviated causing what appears to be a BUZZ on your Audio transmitted signal. Once that level is set then your transmit audio Deviation should be set at +/- 5 KHz with 1 VAC @ 1 KHz audio signal fed into the mic input connector for Analog FM Deviation. Using this method of setting the TX levels will insure that your TR-7600 is not over deviated. Perhaps the repeater 20 miles away does not have a Subaudible Decoder Filter which strips the transmitted CTCSS / PL Encode Tone Frequency out of the repeated audio. I hope you can understand what I'm trying to convey to you.
    Dan
    WA9WVX
