Results 1 to 3 of 3
Thread: Icom SM-5 Microphone
    Mar 2013
    Narangba, Queensland, Australia
    Default Icom SM-5 Microphone
    Hello All From Australia,
    As I am very new to this hobby and don't have a lot of technical know how I was wondering is it possible to get the Icom SM-5 desk microphone to work on a Yaesu FT890 transceiver.
    73's
    VK4FEEL
    Nov 2001
    St Croix, USVI, USA
    AFAIK, the SM-5 uses and electret element, and the Yaesu is designed to work with a dynamic mic. Check the pin-outs of the 890's mic connector. You'll need to figure out a way to connect the AF and PPT/ground lines, as well as provide power to the SM-5's mic element.
    http://ve5kc.amateur-radio.ca/ftp_fi...sm5_manual.pdf
    According to this manual, the AF and power travel on the same pin, pin 1. PTT is enabled between pins 5 and 6.
    http://www.ko4bb.com/Manuals/Yaesu/Y...ing_Manual.pdf
    According to this manual, pins 5 and 6 enable PTT, but AF travels on pin 8 and there's no power coming from the rig at all.
    So in order to use the SM-5 with the 890, you'll need to devise a circuit to reroute the AF and provide power.
    The new signature restriction is bollocks.
    Jun 2005
    Tucson, AZ
    Disregard. I saw SM-5 and immediately thought Shure SM-5, a now discontinued though greatly sought after Low Z Dynamic Microphone used for Vocals.
    Last edited by KA0GKT; 06-17-2013 at 03:53 AM. Reason: Saw the error of my post...
    73 DE KAGKT/7
    --Steve
