ad: palmsprings-1
Results 1 to 10 of 11
Thread: Auto band switch cable for my FT 747 GX to FC757 tuner
    Talking Auto band switch cable for my FT 747 GX to FC757 tuner
    Hi fellow hams.....I recently picked up in new condition a Yaesu FT 747GX transceiver....also got the auto antenna tuner Yaesu FC 757AT in nice condition....It came with the cord that one end has the plug that coming from the tuner (good shape), and the other end of the cord has a rectangle shape plug that fits to the Yaesu FT 757GX tranceiver for automatic band switching and provides the power to the tuner.......This rectangle plug is the wrong fit for my FT 747 transceiver.....It takes an 8 pin Din connector to connect to the 747 transceiver....I checked the manual and this cord; with the proper connector for each end is "D4000019" ....I cannot find this cord anywhere...does anyone know where I can find one with the 747 8 pin Din connector?...If not, can someone provide me any information where I can get this cord modified for the proper fit.....Any information will be greatly appreciated....73 K8ESE
    Quote Originally Posted by K8ESE
    The Yaesu FT 747GX HF transceiver uses an 8-pin DIN connector for BAND DATA.
    I cannot find this cord anywhere...does anyone know where I can find one with the 747 8-pin DIN connector?.
    Amateur Radio equipment does not have Industry Standards such as those established by Intel for WinTel base computers since 1990. This radio and tuner have been out of production for about 25 years !
    TIME to put on your Propeller Beenie cap.
    1. The 8-pin DIN connector is an easily available part in Silicon Valley HRO stores, FRY'S or via mail order (Mouser, Digi-Key). The ACC2 9-pin Molex connector on FC-757AT is also a readily available connector.
    2. Yaesu FC-757AT Manual
    http://www.foxtango.kc9foz.com/Eighties/FC-757AT.pdf
    3. The Yaesu FT-747GX connection is NOT shown in the FC-757AT manual, however the schematic diagram does show the band selection lines routed to the ACC2 9-pin Molex connector.
    Probably best to call YAESU USA SUPPORT, for the correct wiring of that special cable (D4000019) --
    it will be your DIY project to build that cable !!
    Yaesu USA
    6125 Phyllis Drive
    Cypress, CA 90630 USA
    1-714-827-7600
    For Technical Support or Customer Service call, (714)827-7600 between 8AM – 5PM PST
    For Parts Department call (714)827-7600 (8AM – 5PM PST)
    NOTE: READ PAGES 12 and 24 of your FT-747GX manual for proper internal S02 setting (1 or 2) when using the Yaesu FC-757AT.
    N4ATS - Yaesu D4000019 Band Control Cable schematic
    http://www.n4ats.com/?download=D4000019_Schematic.pdf
    HERE are the PIN ASSIGNMENTS, from the FT-747GX Manual and FC-757AT Schematic.
    FT-747GX : BAND DATA (Rear Panel) : 8-pin DIN Circular jack
    Interconnection via Yaesu Band Control cable #D4000019 shown on page 13 of FT-747GX manual.
    1 - +13.8 VDC
    2 - TX GND
    3 - NC (not connected)
    4 - A : BAND DATA
    5 - B : BAND DATA
    6 - C : BAND DATA
    7 - D : BAND DATA
    8 - LINEAR
    FC-757AT : ACC2 (Rear Panel) : 9-pin Molex (0.062" pins)
    http://www.molex.com/molex/products/...y=standard_062
    These lines go directly to CPU Board (#) of this radio.
    GEN/HAM (3) is not connected to 9-pin Molex connector
    1 - GND (1)
    2 - D : BAND DATA IN (7)
    3 - C : BAND DATA IN (6)
    4 - B : BAND DATA IN (5)
    5 - A : BAND DATA IN (4)
    6 - NC (not connected)
    7 - +13.5 VDC (2)
    8 - INHIBIT (8)
    9 - NC (not connected)
    BTW, DO NOT hack or cut that cable for the FT-757GX, that cable is also rare.
    DIY BUILD A NEW CABLE, per K4ATS Diagram (Schematic).
    THEN, READ PAGES 12 and 24 of your FT-747GX manual for proper setting of
    the internal S02 switch (1 or 2) when using the Yaesu FC-757AT.
    Thank you very much for your help!.....I went to the local electronic store a couple of days ago to get the DIN connector (not the mini), and did a "test" plug in with it and it did not fit anyway.....I will check out that valuable information you have provided me.......thank you very much!!
    YES, that could be an issue with the 8-pin DIN -- DIN Connectors:
    http://en.wikipedia.org/wiki/DIN_connector
    There are seven common DIN connector patterns, with any number of pins from Three to Eight.
    Three different 5-pin connectors exist, known as 180, 240, and 270 after the angle of the arc swept between the first and last pin.
    Three different 8-pin connectors exist, known as 240, 262(DIN 41524), 270 (DIN 41326) after the angle of the arc sweet from outer pins.
    http://www.amabilidade2002.com/plugsjacks3.htm
    The MAJORITY of Amateur Radio Equipment uses the 270 version of 8-pin DIN connectors, BUT you need to check. The 262 is also referred to as the Horseshoe. Commodore used this version for their computer ports!
    Thank you very much for your help!....I have been off the air for a few years...Just wandering, is there any modern day auto antenna tuner available that would work with my FT 747 with available band switching connection?...Just a thought if I fail on this project.....But you gave me confidence to work on this old project which I will try
    Cable is constructed...everything works!...thanks everybody...73 de K8ESE Harold
    Great job Harold! Can you share any info? I've got the same project coming up!
    Quote Originally Posted by AB6YA
    I have the same Yaesu tuner interface project coming up!
    The shielded multi-conductor cable (gray insulation) for your DIY cable build
    can be purchased from Jameco or All Electronics, both located in California.
    All Electronics - 22 AWG, Multi-conductor cable
    http://www.allelectronics.com/make-a...nductor/1.html
    Jameco - 24 AWG, Multi-conductor cable
    http://www.jameco.com/webapp/wcs/sto...SEARCH%252BNAV
    Pay attention to the DIN connectors that you purchase,
    especially from Surplus houses or hamfest / computer store bargain bins.
    It is easy to accidentally pick up the Commodore version (262 DIN 41524, Horseshoe).
    K4ATS Diagram (Schematic) for DIY cable build.
