ad: Vari-Ten-1
Results 1 to 8 of 8
Thread: Help: jt65 not decoding
    Jul 2005
    Bismarck North Dakota
    Unhappy Help: jt65 not decoding
    Was using jt65-hf and decoding was going great, then no decodes. Time has been syncronized. Any ideas?
    Mar 2009
    Los Angeles, CA
    time needs to be very accurate. Windows time sync may not be sufficient. I use dimension4 for time updates.
    http://www.thinkman.com/dimension4/d4time50.msi
    Jul 2005
    I too use dimention 4 still no decodes.
    Mar 2009
    Los Angeles, CA
    Quote Originally Posted by K0HAN View Post
    Is your radio using any RX processing that may be distorting the incomming signal? If i select a few of the rx profiles on my ts-590, it will stop decoding. Sometimes a signal too strong will wipe everyone out, and i need to use the atenuator, also.
    Nov 2008
    Большевик
    Another very important that the transceiver is included USB type of radiation at all Bend
    Jan 2006
    Wonder Lake, IL
    What are the parameters you are seeing in terms of Sync, dB and df on any given decode line? Also check and see what you are seeing in the "raw decoder" box (accessed at the top of the active window between "rig control" and transmit log". Also check under "setup"as to what your "rx sample rate" is; should be close to 1.0. Audio input level should be close to "0" with not signals (just ambient noise).
    What you are seeing there will go along way towards defining your problem..
    Bill N9DSJ
    For most digital operations consider checking (until contact is established):
    -AGC FAST or OFF (always)
    -IF Shift/Passband - Centered
    -Noise Blanker - OFF
    -DSP/Noise Reduction - OFF
    -Filters- 1,7khz or wider; Filters OFF if still unable to copy
    -RIT/XIT - Zero or centered
    -Compression /Processor- Off (always)
    When things are not working go back to basics. Turn off all the gadgets and adjustments. Bill
    Dec 2011
    Central NY
    I had the same issue and it turns out Dimension 4 just didn't work anymore for me just out of nowhere. I switched to BktTimeSync and have it sync every minute and I've been fine ever since
    de Jim
