Results 11 to 18 of 18
Thread: Quick update on the Collins S Line project
ad: l-Heil
ad: l-tentec
  1. #11
    Mar 2012
    Biloxi, MS
    Quote Originally Posted by K9STH View Post
    It looks lit to me! The pilot lamp in the 75S- series receivers doesn't give off a whole lot of illumination. Look at the "half moon" under the meter scale and you will see illumination.
    Thanks a million, Glen, for all your help this past month. Let's hope I get the 32S-1 going as well
    Steve AE5DX
    Nice!. Open the top, get your little screwdriver out, unhook the antenna, and set the S meter Zero with no signal. Something probably changed with time or different components, but it's pretty easy to adjust.
    Mar 2012
    Biloxi, MS
    Got the 516F-1 and 32S-1 up and running last night, no smoke!
    However, I couldn't get much else going after that. Most of this is probably due to my inexperience with this rig. I hooked the transmitter and receiver together using patch cords that came with them as per the 32S-1 manual, but could not get past the first step, "Initial Checks" where PA plate current is to be set to 40mA via the Bias Adjustment on the PS. No amount of adjusting one way or the other affected the meter at all.
    I'll keep reading the instructions and see what to do next, but so far so good, I'm not complaining!
    Steve AE5DX
    Check and make sure that there is a jumper between the two RCA jacks on the rear of the chassis marked "PA Disable". There is a permanent connection made at the factory that is removed either to neutralize the final amplifier tubes or to use the 62S-1 transverter. If there is no connection between these jacks, either make a jumper using 2-each RCA plugs or else adding a wire on the inside of the unit.
    To set the bias, put the transmitter in LSB or USB. Then, turn the microphone gain control all the way down. Finally, key the transmitter with the PTT and then set the bias with the potentiometer that is on the power supply.
    If the current on the meter is still zero, then check the bias voltage to make sure that it not only varies but goes down to at least -60 volts.
    Apr 2001
    Ocean Springs, MS (often portable from Moss Point)
    Great job, Steve!
    Mar 2012
    Biloxi, MS
    This will be my next step. Installing a jumper didn't help. Still nothing, and the vox relay goes nuts when the transmitter is first turned on.
    Since this thread has turned technical, I'll be moving any further topics on this subject to the Boat Anchor Forum!
    Thanks to all!
    steve
    Steve AE5DX
  7. #17
    Quote Originally Posted by KF5OYO View Post
    "Jumper!" he said, so jump her I did, that's why I don't work there anymore...
    What if soy milk is just regular milk introducing itself in Spanish?
  8. #18
    Mar 2012
    Biloxi, MS
    Same thing happened to me once, 'cept she was the one who instructed me. Boom, I was out the door!
    Steve AE5DX
