ad: dedicated rf
Results 1 to 10 of 24
Thread: Cheap (Free?) 12 volt power supply from an old computer
    Default Cheap (Free?) 12 volt power supply from an old computer
    Just sharing this. This isn't anything new, but if someone has an old computer laying around, is tight on funds, and needs a relatively small 12 volt regulated power supply for a moderately low output transmitter, using an old computer power supply is pretty easy and quick.
    I put together a quick little YouTube video on the wiring. It's real simple. The old computers I have around here didn't have on/off switches on the actual unit. The main connection plug that goes to the computer motherboard has the on/off wires easily accessible.
    The green wire and any of the black wires can be tapped for a simple switch that is properly rated. For the power supply in the video the unit offers 300 watts, or say 15 amps at 12 volts. Again this isn't for massive high output stuff, but for smaller mobile rigs, or HTs it might be an easy option.
    http://www.youtube.com/watch?v=0PzBeoI6EA4
    Be safe. Have fun.
    Dan
    N3HNA
    Jan 2004
    Quote Originally Posted by N3HNA View Post
    Be safe. Have fun.
    Dan
    N3HNA
    You mean like this one?
    ATX Supply K8ERV .JPG\
    TOM K8ERV Montrose Colo
    Mar 2009
    Carmel, IN
    Nice video, I use an old computer supply for my 10M beacon. Thanks!
    Leroy
    May 2002
    I might point out the 12V supply in these computer things is not a high current supply, and, as shown by the meter, was only 11.59V. This would be ok for a QRP rig, but don't even think of hooking a HF transciever up to it. Or a reasonable power 2M FM. HF rigs usually start to FM once the supply voltage gets down to 12V. That is why I have to use a Battery Booster with my gel Cel. The computer supplies are mainly for the high current 5V, and 12V was just there for some circuitry that needed 12V. I suppose in an emergency it would work. But I will hook my rigs to an Astron.
    I love my cats!
    PHOEBE and PENELOPE MEW!
    Sadly, many will not understand the idea of "start to FM". Maybe an anthology of all the QRZ posted info on power supplies, indexed and consuming a year of time to do so, would help. I am not so sure if it would, though.
    The sendoff of "Be safe, have fun" was never more true, however.
    It would really help new amateurs who want to build antennas to find an older copy of the ARRL Antenna book. There are too few explanations and too little data in the current editions. By old I mean say pre-1989. Cruise hamfest tables and Ebay, there are plenty available pretty cheap.
    Jan 2004
    I might point out the 12V supply in these computer things is not a high current supply, .
    I think you mean not a high voltage supply. The current depends on the PS wattage rating, mine puts out
    10 amps easily. Some supplies have a trimpot that can boost the voltage a bit, but probably not to 13.8.
    But the price is right.
    Great comments. Many thanks. Exactly something like that, Tom - good job.
    And, yes, without any major modification this is for smaller rigs. The price is certainly right.
    Good idea for a beacon supply, Leroy. I hadn't thought about that.
    Dan
    N3HNA
    With many (maybe most) PC supplies, especially the older AT and ATX versions, the loading on the +5V bus allows the +12V bus to properly regulate and will also effect the output voltage on the +12V rail.
    I have some here that with a 5A load on the +5V rail, the output is actually about 12.6Vdc on the +12V rail. If I reduce the +5V load to only 1A the power supply still functions but the +12 drops down to about 11.9 or 12.0. It makes a rather large difference.
    Of course the 5A load on the +5 dissipates 25W which is just "thrown away," but might be useful for a bunch of LEDs or something.
    Feb 2004
    Bakersfield, CA
    Take a look at the article in the AntenneX preview files. There's a 15VDC 40A power supply and using the limits of plus or minus 15% of 13.8VDC for almost all the rigs out there the 15VDC is an acceptable level.
    The download is here at; http://www.antennex.com/preview/. Just below the page intro are the listings of things you are allowed access. A few are restricted and they'll tell you so when you try to view them but the others are for you to enjoy. The 15VDC 40A supply is on the left list just about the bottom.
    BTW Steve that's a lot of LED's. Perhaps you wish to light up the room?
    Have fun
    Have fun
    I don't like the idea of using a "15 Volt" supply for my radios. That's right at the limit (or within one volt) specified for many of my radios, and a spike or even small overshoot can exceed that. Even 14 Volts is more than necessary for most radios, and will not accomplish anything other than generating a bit more internal heat.
    If the "15 Volt" supply could be adjusted down to 14 or 13.8 Volts, I'd feel a lot more comfortable about attaching one of my radios to it.
    One drawback to using old PC type computer supplies to power radios (aside from the possiblity of being on the low side of 12 Volts) is that many are poorly filtered, and can cause horrendous RFI. Just a caveat to consider. YMMV
