ad: BXcom-1
Results 1 to 4 of 4
Thread: Yaesu FTM-350 144/220/440 MHZ mobile
    Talking Yaesu FTM-350 144/220/440 MHZ mobile
    This is ONE Yaesu FTM-350 144/220/440MHZ mobile with box,manual,wiring,screws,bracket and preprogrammed for NJ,NYC area repeaters mostly all of them from repeaterbook.com.It is in great shape,non smoking home,never been mobile.1000memories with alphanumerics,50 watts on 144/440 and 1 watt on 220.It has wideband receive and am,fm stereo(yes stereo).Fast scanning,loud yaesu transmit and receive audio.Selling because I am not working.$450 no paypal.....I accept money order or certified bank check,or western union.This has voice option.
    And I must write this,if you dont like the ad,just ignore it,no Bashing,dont lo-ball.
    I am in NJ.respond via PM (personal message) ONLY.Thanks.
    Photos taken with flash so appearance may look dusty,but its not.
    1. Uses the worldwide accepted GPS NMEA data format
    2. APRS® BEACON station is possible, even if the beacon station is moving.·
    3. Waypoint data (Data in/out) is available from the ACC connector on the rear of the main unit. It is possible to acquire your current position (Latitude/Longitude) by connecting an aftermarket GPS receiver to the data port on the back of the radio.
    4. Sub-Band APRS® operation may be active in the background, even when operating in the Mono-Band Display mode.
    5. Newly added Voice Alert function.
    6. Often used keys located in convenient positions for easy operation.
    7. Programmable keys on the DTMF Microphone provide direct access to APRS® functions.
    * 220 MHz 1W (USA version only)
    Yaesu specs courtesy of yaesu
    Lots of Reliable Power Output
    50 Watts of Reliable Power on both 2 m and 70 cm. 220 MHz 1W (USA Version)
    Yaesu's renowned high quality Die Cast Aluminum Chassis design allows stable continuous high output power operation when you need it most.
    Fantastic Large and Flexlible LCD Display
    Incredibly flexible Dual Band Display. You can easily set your own individual preference for Dual Receive and Full-Duplex operation. 5.2"x1.6" (130x40 mm) Large dot matrix (264x64 dots) LCD display for comfortable viewing - night or day.
    Numerous useful displays are available with the optional FGPS-1 GPS Receiver and Antenna. (Optional FGPS-2 External GPS Receiver and Antenna + CT-133 (cable) + CT-136 (adapter) are also available.)
    Choose your favorite LCD display color - 8 vibrant Color Options!
    Loads of APRS® Flexibility
    Complete with TNC and compatible with various APRS® information and functions - Receive WX info from other APRS® weather stations, exchange messages (max 67 characters using the APRS® function, etc
    Dual Speakers on Control Head
    Built-in Dual Speakers on the rear of the Control Head with Independent Volume Controls for maximum flexibility
    Control Head Separation with Ease
    The Display Control Head is designed for easy separation from the main RF Power Unit - 10 foot control cable included. Optional 20 foot control cable available.
    Band Scope
    High-speed Band Scope included for rapidly checking band activity.
    Bluetooth® Capabilities
    The optional Bluetooth Unit (BU-1) provides hands-free radio operation with our Optional Bluetooth headset BH-1A (stereo) or BH-2A (monaural).
    SmartBeaconing™ Included
    SmartBeaconing™ from HamHUD Nichetronix is able to modify its own beacon rate in response to the motion of the vehicle. Since the APRS network has limited bandwidth, SmartBeaconing™ transmits an optimal amount of position information with a minimal amount of QRM to other network users - making FTM-350R users some of the most "efficient" on the network.
    Read more about this very useful feature at http://www.hamhud.net/hh2/smartbeacon.html
    Cross-Band Repeat Capability
    For emergency work, or to extend the range of a hand-held unit, the FTM-350R includes Cross-Band Repeat capability.
    Huge Memory Channel Management Capability!
    500 Independent memory channels with memory name tag function (up to 8 characters) for each L and R band (1000 channels total), + 9 PMS (Programmable Band Limit Memory Scan) channels for each L and R band (18 channels in total), + a rewritable preferred channel for each L and R band, + 31 channels specifically allocated for the Smart Search function
    Special Features when communicating with FTM-350R & VX-8R/DR Transcievers
    Able to display your friends APRS® stations (FTM-350R and VX-8R / DR) directions, distances and other information in relation to your location.
    Packet Compatible
    1200 / 9600 bps packet port (8-pin mini DIN)
    Wideband Receiver
    Wideband Receive:
    L-band: 0.5 MHz – 1.7 MHz (AM Broadcast band)
    76 MHz – 108 MHz (FM Broadcast band)
    108 MHz–250 MHz / 300–1000MHz
    R-band: 108–250 MHz, 300 MHz–1000 MHz
    (USA : Cellular Blocked)
    Listen to FM Broadcast Stations in Stereo
    Built-in stereo decoder for FM Broadcast: Listen to FM Broadcast in Stereo with dual speakers on the rear of the control head!
    Optional FPR-1 Monitor Unit
    Optional FPR-1 Monitor Unit receives your transmission out to about 1,000 ft (300 m) depending on transmit power and other conditions. Give to others to hear your transmissions during emergencies, special events, and so many other operations so that they can follow the situation.
    DTMF Microphone Included
    The front panel Built-in Microphone activates PTT transmission. A MH-48A6JA / conventional hand microphone with DTMF is also included with the radio.
    DTMF Autodial
    DTMF Autodial (Memory) with 16 digits/9 memories
    "Line In" input permits playing your favorite stereo music from other devices.
    Barometric Pressure Sensor
    Built-in Barometric Pressure Sensor - The radio can monitor and display your altitude and pressure.
    This ad was posted by K2OOL ARTHUR C ELLIOTT, CLIFTON, NJ 07014,
    K2OOL joined QRZ on: 08-23-2009 IP: 174.44.96.106
    If no email address or phone was given, click HERE to send K2OOL a private message.
    Price is $425.00
    price is $400 if youre local to northern nj
    Consider trade for AOR-8600MK2
