Last Sunday evening The High Altitude Balloon Group Near Space Sciences launched EarthBreeze II, their 51st of these high altitude balloon experiments. We have been doing these flights for almost 25 years now and are always trying something new.
All was going well for the first three hours of flight. Then as it was nearing the coldest altitude, It began to operate oddly. Maybe some background of the flight is in order here first. Please go to the following web page to learn all about this flight. It is a very unique flight.
Joe WB9SBD
Mission Director
Near Space Sciences
nss@mwt.net
"Lossy Traps, Oh my!"
TRANSMISSION DETAILS:
ANTENNA: Vertical Wire Dipole
Mark, K8MHZ
-W9JEF
BUT!!!
Joe
Sounds like fun.
K5CO
Bill KC9XG
Bill KC9XG
See Post #5?
Joe
Whatever goes up must come down. The vertical dipole antenna would likely be collapsed or destroyed when it hit the ground. Maybe, just maybe, the transmitter is still functioning but without an effective antenna, it would not be very efficient. Someone might be able to hear it via groundwave and use this to locate it. Users along a forecasted track could be alerted, if the forecasted track is not classified information.
Bill KC9XG
