ad: giga-rw
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: New old stock heathkit HW -101
    May 2003
    Everett, WA USA
    Quote Originally Posted by W7BLD View Post
    Clean tube sockets as well.
    For that, removing/installing the tubes a few times sometimes* resolves a bad tube-socket contact issue. And, you need no tools/cleaner to do it. At the least, it can sometimes* identify the offending tube-socket contact.
    * ZOOK: this means not ALWAYS
    vy 73,
    Bryan WA7PRC
  2. #12
    If the contacts in a tube socket have lost tension and thus the tube is not always making a good connection, the contacts can usually be tightened by inserting an Xacto Knife with a #11 blade between the outside of the contact and the insulation of the socket and twisting a few degrees. Do this on both sides of the contact.
    The first time the tube is inserted into the socket, it may take a little force. However, after the tension is returned, problems with tube connections are going to be a long time before they reappear.
