Quartz Crystal Tester
Looks good.
Does it work with Galena?
TOM K8ERV Montrose Colo
I like the simple CMOS inverter crystal tester. Take a 4011 NAND gate and connect the two inputs together. Ground them through 22 pF. Place a 10M ohm resistor from the inputs to the output. Connect the XTAL across the 10M resistor.
Hi OM Dave,Sure! It's only for nostalgia's sake!73Nandu.
Sometimes CMOS can be picky about frequency especially if it has a 5Vdc power supply. I usually use a SN7400 or other IC's in it's class. It works just fine and it really put out the harmonics.
Good job Nandu.
 Originally Posted by KO6WB
Sometimes CMOS can be picky about frequency especially if it has a 5Vdc power supply. I usually use a SN7400 or other IC's in it's class. It works just fine and it really put out the harmonics.Good job Nandu.73Gary
Thanks, Gary!73Nandu.
