ad: wmr-top
Results 1 to 10 of 11
Thread: AL- 80B Works on and off
    Default AL- 80B Works on and off
    I have searched and have not found an answer yet.
    The AL-80B is only about 3 years old. I drive it with Ft-897 going through Ameritron ARB-704. A few months ago it occasionally would not kick on and my swr is high, but on standby swr is ok. Also now on the meter, And while just idling the plate IP will jump up to about 100 and the Grid will go negative. Still sometimes when the meters settle down and it will transmit at normal power but sometimes the next key down no power. I have never over driven it. I run between 50-60 watts into the amp.
    KF5BQJ
    north central Connecticut
    Sounds like a bad soldering connection in the metering resistors.
    May 2005
    Holland JO23TA
    Bad or loose connection in or around the tube.
    Licensed since 1977
    Any sign of plate current and negative grd current "IN IDLE" (not keyed) is a sign of an intermittant grid to filament short. Nothing can make the meters show any current otherwise. It's not a bad connection.
    Quote Originally Posted by W1QJ View Post
    Yep, that's what I'd say, too. Likely time for a new 3-500ZG.
    Would this allow the amp to still perform with the same output as normal some time. ?
    Quote Originally Posted by KF5BQJ View Post
    It surely could.
    Mar 2012
    New England
    Quote Originally Posted by PA5COR View Post
    Ignore this reply. Mouse problems.
    Quote Originally Posted by AB1QP View Post
    I have some mousetraps that take care of that. Found they like peanut butter better than cheese.
    They also like In and Out Catchup.
    Sue
    A
    F6LJ
