ad: giga-rw
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Sacrilege
    Jan 2002
    harms way
    Default Sacrilege
    As an true Icom fanatic this saddens me. Not only is smoking hard on the radio imagine what their lungs must look like!
    Cough.
    More about the faith:
    http://www.icom.co.jp/world/company_profile/history/
    now with true viterbi decoder!
    Mar 2003
    Ceti Alpha 5... otherwise known as Texas.
    Isn't there a liquid, plastic-safe cleaner that you can just dip the whole radio into that would dissolve/remove all that gunk?
    I bet that if there is a computer nearby where the radio lived its innards are caked with tar, too. Yuk!
    Jan 2002
    harms way
    Dunno if there's a miracle cleaner to clean that up in one go but he sure made it look better!
    The guy sure did it the hard way!
    Rubbing alcohol is OK - but the yellow, regular formula "Listerene" mouthwash ( regular or store brand ) cleans that crud away LOTS faster.
    Back in the old glass-tit CRT days, I used Listerene to clean computer monitors. No streaks, plainly superior to actual glass-cleaning products. - Cheaper too, needless to say!
    It is also superior for removing accumulated dead skin and grime ( scum-grip ) on the steering wheel and arm rests in an old car or truck.
    I wouldn't use it on a guitar fingerboard as the alcohol in it would tend to dry out the wood - but I would not hesitate to use it on the body of the guitar.
    They end up with scum-grip on them, just like an old car's steering wheel.
    I have used it to restore a few old Kenwoods and recommend it highly.
    As with all clean-up stuff, test it on an area that is invisible or hard to see before you start using it on the front panel and its lettering - to be sure that its ingredients are compatible with your particular radio's finish.
    73 DE Charles, N5PVL
    The "S" word... It's not the socialism, it's the stupidity behind it.
    Jan 2002
    harms way
    Thanks Charles!
    Mar 2003
    Not only that, Charles, but it leaves your radio minty fresh and prevents its filters from getting cavities.
    I hope this doesn't mean that a cherry IC-765 is about to hit the market.
    Heh
    May 2002
    Crest, Ca (just East of El Cajon)
    Here is my experience with smoke! This Johnson 6N2 VFO was a sticky dark brown when I got it. I had to use the NOVUS #2 to burrow through the smoke to get to new paint which was grey!
    GAWD...
    That radio was disgusting.....
    It sure cleaned up nice though.....
    I generally replace meter lamps with lamps and add a ten ohm resistor to limit inrush current.
    The end result is unless the radio gets a lot of shock and vibration you only replace the bulbs once.
    A
    F6LJ
    You cannot rule an educated population.
