Originally Posted by
WA9SVD
With all due respect, that's incorrect. a dipole is inherentlly a BALANCED radiator. Directly feeding such an antenna with coax (an UNbalanced feedline) can and often does induce currents on the OUTSIDE of the shield of the coax, where it's lloe function is to cause RFI, TVI, and as the OP has experienced, RF burns. One immediate solution (or at least partial solution) would be to put a BALUN at the dipole feedpoint. The type will depend upon the actual dipole configuration. If it's a single band dipole, a 1:1 BALUN would be appropriate.
