ad: giga-rw
Results 1 to 3 of 3
Thread: Inexpensive mic for a Kenwood TS-520
    Default Inexpensive mic for a Kenwood TS-520
    I've newly earned my ticket (General) and have most of the pieces I need to get on the air in HF. I still need a couple of items, and want to do so for a minimum amount of money. I may (and probably will) upgrade things in the future but I want inexpensive to start.
    I have what appears to be an at least mostly working Kenwood TS-520. I do not have a microphone for it. Given that I'm not even 100% sure it works (it receives, and tunes into a dummy load, and it worked 15 years ago) I don't want to spend a lot to start to get a mic. I know it needs a high impedance microphone, so it's not as simple as it might be.
    What's the least expensive way to get a reasonable mic for this thing?
    Thanks, and 73!
    Mike (itching to get on the air)
    If you can solder, almost any mike (dynamic, ceramic, crystal) will work with the 520. It's mostly a matter of soldering on the 4-pin connector.
    I've used the 520 with everything from a D-104 (very high impedance crystal mike) to a Shure 444 (controlled reluctance mike) to a Heil PR40 (low impedance dynamic mike) and they all worked fine.
