ad: giga-rw
Results 1 to 5 of 5
Thread: two meter squalo antenna help
    deland fl
    Default two meter squalo antenna help
    I need some help to repair a two meeter squalo antenna .
    this is the square type with a rod type gamma match and the small cap at the end where mounted has broken .
    i don't know nor can i find any information on the size needed to replace.
    the cap is very small about three eights of an inch in dia.and was potted at the mount.
    any help would be most welcome thanks to all in advance. Frank ka4dsk
    It's the same "Redi-Match" (gamma match) as used on the current model Cushcraft A147-11 and other two meter CC antennas. You can buy a replacement from them.
    deland fl
    Default two meter squalo help
    thanks steve for quick reply.I looked up the cush craft parts as suggested and they do not look the same as used on the squalo .the squalo has a
    small capacitor that is potted on the end of the rod .the connection on the one i have is broken where the connection was made to the rod. the parts for the cush craft units have a plastic sleeve or tube and do not show any small attched capacitor?
    May 2001
    Roswell, NM
    That's exactly why I don't use one. Instead I use M-Squared's versions. I have a 6 meter one that has about 100,000 miles on it. It's still going strong, but I have had to fix the brace a couple of times. The 2 meter, and 70 cm loops don't have the brace.
    I can tell you the loop worked perfectly today on 6 meters. The opening wasn't long in tooth, but this is the first time in a long while where 6 was open to Europe from New Mexico. A couple of XE stations were fairly loud too.
    Alan Applegate, KØBG
    http://www.k0bg.com
    Quote Originally Posted by KA4DSK View Post
    Yes, I know that. I remember the Squalo, and the "original" A144-11 and A144-7 etc. all had EXACTLY the same Redi-Match with that molded plastic capacitor. They all had the same one. CC updated that design to get rid of that silly thing, because in weather and sunlight exposure over time, they all failed. The "new" Redi-Match is better, and I'd use that one.
