11 years of use from a PC is fantastic....however, it's about 7 years past needing to be replaced. I would not trust it to hold anything important, it's living on borrowed time. Unless your other PCs are in the same age group, you may run into trouble getting MS Money to even run. Microsoft discontinued support for MS Money in 2008.
Nice job on the power supply fix! I probably would have recycled the PC and found a replacement.
FCC Section 97.313(a) “At all times, an amateur station must use the minimum transmitter power necessary to carry out the desired communications.”
Flying Pig -57 NAQCC 18 ARCI 10223 SKCC 2076T FISTS 5695 CC 764 SOC 400
