Page 5 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 41 to 50 of 110
Thread: TS-820S Doesn't Power Up
  1. #41
    Make sure and run the switch in several directions immediately after applying the WD-40.
  2. #42
    Jan 2011
    Houston Texas
    Quote Originally Posted by K9STH View Post
    That is a must do.
    I don't think WD40 is the same as it used to be.
    I have used WD40 on many TV tuners in the day, but have found better stuff to use now a days.
    The Over Spray is not good if the spray tube is used. I use Q-Tips.
    73 DE KA9JLM Don
  3. #43
    Jan 2011
    Houston Texas
    Quote Originally Posted by KF5IYL View Post
    I'd never thought of using WD-40 for contact cleaning. I just put a small amount in the contacts, and I'm going to wait until I'm sure it's dry before I try to power it on. I'll keep y'all updated on what happens!
    You may be waiting a while for it to completely dry out, Weeks.
    Crank it up and give us a report.
    73 DE KA9JLM Don
  4. #44
    Quote Originally Posted by AF6LJ View Post
    If it receives it should transmit.
    You've obviously never owned an Icom 746!
  5. #45
    Any tips for cleaning it, or is it just like any normal rotary switch?
    Q-Tips doesn't take much solvent.
  6. #46
    Nov 2010
    Texas!
    Hmmmmmmm. . . Still isn't working. . . And, now I can't reproduce what I did earlier by fiddling with the band switch. . . Sorry to keep bothering you guys, but any more ideas? Or should I let the WD40 dry longer?
    "Don’t let anyone look down on you because you are young, but set an example for the believers in speech, in conduct, in love, in faith and in purity." - 1 Timothy 4:12
  7. #47
    This is what we are here for, to help.
    A
    F6LJ
  8. #48
    Jan 2011
    Houston Texas
    Did you clean the contacts in the RF PA cage also ? Be careful of the high Voltage.
    You may want to clean the CAR control as well as the other controls.
    73 DE KA9JLM Don
  9. #49
    Nov 2010
    Texas!
    Yes, but I didn't do the CAR contacts. I guess I'll go clean those now.
  10. #50
    Nov 2010
    Texas!
    Still nothing.
