I am in need of the plug that fits into the acc jack of an Icom 706mkll don't need the Icom's expensive
cable need the plug for a project.
Any help with part nbr.,supplier would be helpful.
Thanks Roger AK4QQ
Soldering these TINY pins is tough!! Built a cable with one once. Be careful! Don't forget to put the hood on the cable, and in the proper orientation first!!
The best way is to figure out which pins you are going to use, do it twice. And then cut off the rest. You will find the ones you need are scattered out and easy without the forest in the way.
