ad: tentec
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
Thread: RG-213 COAX LOSS
  1. #11
    Wait a minute!
    The inverse log of (0.855/10) is 0.821296552. Multiplying by 50 watts gets 41.06482764 watts. That is 0.000172358 watts more output!
    That extra bit might overload my receiver.
  2. #12
    May 2003
    Everett, WA USA
    Quote Originally Posted by K4SAV View Post
    It probably depends on who's brand of RG213 you have, as well as the calculator used.
    RG-213/U carries a Mil spec. Therefore, the brand does not matter or, it's not RG-213/U.
  3. #13
    The question was about RG213, not RG-213/U.
  4. #14
    Jul 2009
    FN13
    I see what I did. I used two different calculators which had different specs for "RG-213". I didn't check my math, must've been the sun spots.
    50 watts in you'll get around 41-42 watts out not taking into account connectors, relative humidity, phase angle of the sun and day of week.
    Electricity takes ALL paths to ground, not just the least resistive. -Guido
  5. #15
    In Missouri Ozark Mountains
    Use LMR-400 even less loss or hard line many times can be picked up for free the best.
    73 de Fred N0AZZ
    ARRL member, ARRL and W5YI VE
    DX the thrill of the chase
  6. #16
    Jerry. K4SAV
    TRUE RG-213/U should have the same loss, (within mil-spec tolerance) regardless of manufacturer. That's the whole point of mil-spec cables.
    A designation of RG213 is meaningless.
  7. #17
    deleted - correcting errors ...
  8. #18
    The mil spec (M17/74-RG213) only specifies the maximum attenuation. If you are trying to calculate the exact attenuation you need the data from the manufacturer of the cable.
  9. #19
    Actually, even within various production runs of cable the attenuation may very well differ slightly. Therefore, the best way to determine the attenuation is to actually measure the loss in the cable.
  10. #20
    Of course. The manufacturer's published specs will give a "nominal" value for such features as attenuation, impedance, and even diameter, all of which can vary slightly from lot to lot. But most Amateurs don't have sufficiently accurate equipment to determine loss in a short, or even moderately long, piece of coax. 0.1 dB or so difference from published data would be difficult for most to measure.
