Results 1 to 2 of 2
Thread: POWERSTAT TYPE 1256D Variable Transformer 240vac input 7.8KVA CCS rating
    Default POWERSTAT TYPE 1256D Variable Transformer 240vac input 7.8KVA CCS rating
    Powerstat 240vac 7.8kva CCS P/UP only
    NO PAYPAL PICKUP ONLY in Fort Wayne, In 46805 Send phone contact is first email. These are commonly call a variac, Powerstat TYPE 1256D, panel mount. Weighs over 100lbs. $350 Firm, cash on pickup, this price will not be lowered. You must remove from supply. I put it in, but am now unable to handle the weight. Has a large cast wheel to control voltage, included. Very clean, in a non smoke non pet home. 240vac 50-60HZ input 240vac or 280vac output. 7.8KVA CCS. At rated amp load with 240vac output the rated voltage drop is 1 volt ac CCS. Rated to operate at up to 500HZ AC at reduced rating. In/out put screw down lugs accept up to 6 gauge wire or less and are clearly marked, no soldering.
    Can eMail the spec sheet to a serious buyer, Will Not Ship. Thanks Al K9FW K9FW at Arrl dot net.
    This ad was posted by K9FW ALBERT S BIDDLE, FORT WAYNE, IN 46805 IP: 184.18.35.234
    To inquire about this listing, please contact the seller directly as specified in the ad.
    If no email address or phone was given, click HERE to send K9FW a private message.
    QRZ assumes no responsibility for the accuracy of this listing.
    SOLD This Powerstat
