Is it possible to reverse calculation of coax transformation ratio?
Say we have some antenna, feed with 12 meters of RG-213 coax. Impedance at TX end is say R28-jX 200, frequency is 7.1 mhz. Knowing coax type and it's characteristics, can we calculate it's transformation ratio, so we'll know what is the antenna impedance at feedpoint?
Sure, it can be solved for. One easy way to do that is to use VK1OD's calculator:
http://vk1od.net/calc/tl/tllc.php
Choose your coax type, length, and frequency and choose "Zin" in the drop down "Mismatch" menu instead of "Zload"
I get a load impedance (at the antenna) of 1.3-j62 for your stated parameters.
Dan
Heheh, I've being used that calculator for ages, but haven't thought about it that way. Thanks. The parameters I provided were just example, no real system.
