For sale is a modern high performance military HF Transceiver, RT-9000B from Sunair, a US manufacture of high-end military HF equipment. The RT-9000 is a Mil Spec SSB/AM/CW /Digital HF Transceiver with 125 Watts output and a frequency range of 100kHz to 30 Mhz for RX and 1.6 Mhz to 30 Mhz for TX. The Transceiver has Build In Test (BIT) for receive and transmit that it passes without problems. Further more the Transceiver works perfectly and has no issues. For more information please Google for Sunair RT-9000B and you will find a datasheet in PDF format. The Transceiver comes with 110VAC power cord, manual, headset and microphone. Also included is an additional Microphone/Data connector.
If interested, please send your serious offer via e-mail to df9WU@yahoo.com. 73 es tnx de NC6X.
