Results 1 to 5 of 5
Thread: microphone specs
ad: L-rfparts
    Default microphone specs
    I have a Kenwood 2000 and want to rig up myown boom mike. What specs do I need for choosing a mic?
    Caroidid(?) Dynamic Omnidirctional? Any comments?
    Cardioid dynamic is a good choice. Omnidirectional is usually a terrible choice.
    This one is a lot of bang for the buck: http://heilsound.com/amateur/product...oductsheet.pdf
    What if soy milk is just regular milk introducing itself in Spanish?
    Oct 2001
    Jurupa Valley CA US
    A mini-review of that Heil HM-12 is at ...
    http://www.k6lcs.com/k6lcs/HM12.html
    Clint K6LCS
    Clint Bradford, K6LCS
    http://www.work-sat.com
    You need a low impedance microphone, which gives you a WIDE selection. Keep in mind that this is ham radio, not broadcast. You don't need to spend a king's ransom. Heil and others make works of art but, 99.9% of the time, the station on the other end isn't going to be able to tell the difference.
    When I use a boom-mounted microphone, I use a $20 RS #33-3038 (unidirectional, dynamic 600Ω) microphone. The specifications compare favorably with more expensive microphones. I've received many unsolicted comments, saying it "sounds as good as a Heil".
    I spent $50 on a low-rise long-reach boom (Hercules #MS540B). I use a floor flange and short section of pipe to secure it to the corner of the shelf above my wide operating table.
    But, most of the time, I use a headset (Heil ProSet Plus). No matter which way I turn my head, the microphone is ALWAYS in the right spot. Like a boom-mounted microphone, it leaves my hands free and (most importantly) doesn't occupy valuable operating desk real estate. Unlike a boom-mounted micrphone, there is no mounting to deal with, and it blocks out background noise (which can be good and/or bad).
    With both microphones, I use the Heil FS-2 footswitch (about $40) to keep my hands free to log & operate the rig. There's cheaper out there but the FS-2 is built like a tank and has two microswitches (one for the rig and one for an amplifier).
    Apr 2007
    Levittown, PA
    I use a MXL990 condenser mic and it sounds great. You will need some sort of preamp such as a Behringer VX2000 to provide the power for the mic and enough signal for your rig. I think I paid $50 for the mic from Musician's Friend
    Tom - AB3FL
    I may not know CW, but I can operate a boatanchor!
