The good news about those tensioners is that they're readily available at WalMart, too. I use them with Dacron rope and telescoping masts so can also recommend them.
73, Jeff
Why can't you just cut some shorter guys with some turnbuckles and attach them to the same point on the mast as the long guys and let them dangle on the pole when up. maybe cut some ply wood or a 2x4 or something like a small donut/ring around the pole with some hook eyes and attach the short guys to it so they dangle down weighted. The easiest thing would be separate tying off the guys on the pole and instead provide something on the pole that you can hook the guys, and as well on the ground. That way you can make guys for either up or down and hook up the ones you need as needed. When the pole is up, use the long guys. when the pole is down use the short ones and wrap up the long ones.
K4PP
Another vote for the black dacron rope. I had it up for 2 years, had to move, it sat in a back garage for 3 years, moved back, pulled the rope out expecting a rotted useless mess. Nope, it was a little stiff from being wet and then drying all coiled up, but beside that it was good as new.
Thank you everyone, I think I have a much better idea of where I want to go with this now!
I may go ahead and trade the rope out for the Dacron stuff, if I can find it at Home Depot I'd be satisfied. And maybe those line tensioners too. In the mean time I may have to see if I can give that midshipman's knot a try.
Thanks!
Thanks!
I've been using Nylon for the past 40 years with zero issues. Whatever the material, double-braided will stretch less than twisted or single braided construction. I buy it from the local mariner supply places. McMaster-Carr has a good description of various fibrous ropes.
Thinking about the cable tensioner I remember back on the days I went camping and the tents had those plastic adjusters on the lines. Those hold very well and they are easy to use with just about any size line you can come up with. There are some at; http://www.ultralightdesigns.com/pro.../microLoc.html. These are cheap.
Or ;http://www.campmor.com/taut-tie-guy-...rs-small.shtml.
There are some more you can get, just do a search.
I'll plead ignorance here.
Your guy rope broke so it was not strong enough to do the job?
So what is holding you to get something stronger?
Some folks call it “parachute cord” - usually black Dacron available in variety of strength ( I use 200 pounds) and in better hardware stores. Or e-nay.
If the antenna, I do not know what Buddipole looks like, is somewhat flexible you should not have to tie the guy so it plays you favorite melody. Little “give” may work too.
BTW – do you really need the turnbuckle? I would not be surprised that the rope twisting undid the turnbuckle tension in a hurry anyway. Less hardware is usually better.
73 Vaclav
The last step with a turnbuckle is to always feed the cable or rope back through it and tie it off so it can't twist.
Guying anything that goes up and down a lot seems like a lot of work to me. I'd rather use something stronger or tilts up and down using a pulley and pull rope (or winch), or "something."
I never said the guy rope actually broke or that the turnbuckles unscrewed, it's a long story, but I'm not opposed to getting stronger rope at all.
