Ok I made up a Glitch resistor. Put 2 Plastic tie wrap holders down on bottom of amp. One you could see was holding my fuse holder in place. Surrounded by Electrical tape. Solder in line a 10 ohm 10 Watt wire wound resistor with 2 layers of heat shrink on both ends and put it inside a plastic "shelf" if you want to call it that. See picture. Sorry blurry getiin old ya know! Opinions please! Anything else I should insulate?
