ad: N3WG-1
Results 1 to 8 of 8
Thread: Icom IC-756PROII 100W Tranceiver
    Oct 2001
    Missouri and Kansas
    Default Icom IC-756PROII 100W Tranceiver
    I am selling my spare IC-756PROII 100W HF Transceiver - As New - In the box.
    I am the original owner. I purchased this radio new some years ago as a spare. The radio only has a few hours of usage. I am looking to purchase an IC-7700 and am clearing some extra equipment out my shack . I have powered this radio this past week to test it thoroughly, and it is truly an awesome professional radio! Compare it's newest cousin, the IC-7600. The only truly apparent differences I see are that the 7600 has roofing filters and a larger display screen. I'm sure serious DX'ers would add to the list, but with CW as my primary mode, these models have thoroughly served my purposes well with 599 reports all over USA, CA, Mexico, Europe, etc. The radio comes with all original accessories in the original packaging with original printed owner's manual.
    I am asking $2,000.00 USD - Or best offer (OBO)
    Thanks for looking! Radio information appears below this post.
    Best 73!
    Scott - n0nuf
    Click image for larger version.
    10. Specifications
    GENERAL
    • Frequency coverage :
    U.S.A. Rx 0.030--60.000*1
    Tx 1.800-- 2.000*1 3.500-- 3.999
    7.000-- 7.300 10.100--10.150
    14.000--14.350 18.068--18.168
    21.000--21.450 24.890--24.990
    28.000--29.700 50.000--54.000
    Europe Rx 0.030--60.000*1
    Tx 1.800-- 1.999 3.400-- 4.099*1
    6.900-- 7.499*1 9.900--10.499*1
    13.900--14.499*1 17.900--18.499*1
    20.900--21.499*1 24.400--25.099*1
    28.000--29.999*1 50.000--52.000
    France Tx/Rx 1.810-- 1.850 (France)
    Italy 1.830-- 1.850 (Italy, Spain)
    Spain 3.500-- 3.800 7.000-- 7.100
    10.100--10.150 14.000--14.350
    18.068--18.168 21.000--21.450
    24.890--24.990 28.000--29.700
    50.200--51.200 (France)
    50.000--51.000 (Italy)
    50.000--50.200 (Spain)
    *1 Some freq. bands are not guaranteed.
    • Mode : USB, LSB, CW, RTTY, AM, FM
    • Number of memory Ch. : 101 (99 regular, 2 scan edges)
    • Antenna connector : SO-239×2 and phono [RCA; (50O)]
    • Temperature range : --10°C to +50°C; +14°F to +122°F
    • Frequency stability : Less than ±0.5ppm (From 1 minute after
    power ON at 0°C to 50°C; +32°F to +122°F)
    • Frequency resolution : 1Hz
    • Power supply requirement : 13.8V DC ±15% (negative ground)
    • Power consumption : Tx Max. power 23A
    Rx Standby 3.0A (typ.)
    Max. audio 3.3A (typ.)
    • Dimensions : 340(W)×111(H)×285(D) mm;
    (projections not included) 133/8(W)×43/8(H)×117/32(D) in
    • Weight (approx.) : 9.6kg; 21.2lb
    • ACC 1 connector : 8-pin DIN connector
    • ACC 2 connector : 7-pin DIN connector
    • CI-V connector : 2-conductor 3.5 (d) mm (1/8?)
    • Display : 5-inch (diagonal) TFT color LCD
    TRANSCEIVER
    • Output power : SSB, CW, RTTY, FM 5--100W
    (continuously adjustable) AM 5--40W
    • Modulation system : SSB DPSN modulation
    AM Digital low power modulation
    FM Digital phase modulation
    • Spurious emission : 50dB (HF bands)
    60dB (50MHz band)
    • Carrier suppression : More than 40dB
    • Unwanted sideband suppression:
    More than 55dB
    • TX variable range : ±9.999kHz
    • Microphone connector : 8-pin connector (600O)
    • ELE-KEY connector : 3-conductor 6.35 (d) mm (1/4?)
    • KEY connector : 3-conductor 6.35 (d) mm (1/4?)
    • SEND connector : Phono (RCA)
    • ALC connector : Phono (RCA)
    RECEIVER
    • Receive system : Triple conversion superheterodyne system
    • Intermediate frequencies : 1st 64.455MHz (for all modes)
    2nd 455kHz (for all modes)
    3rd 36kHz (for all modes)
    • Sensitivity (typical) :
    SSB, CW, RTTY 0.16µV*1 (1.80--29.99MHz)
    (10dB S/N) 0.13µV*2 (50.0--54.0MHz)
    AM (10dB S/N) 13µV (0.5--1.799MHz)
    2µV*1 (1.80--29.99MHz)
    1µV (50.0--54.0MHz)
    FM (12dB SINAD) 0.5µV*1 (28.0--29.9MHz)
    0.32µV*2 (50.0MHz--54.0MHz)
    *1Pre-amp 1 is ON, *2Pre-amp 2 is ON
    • Squelch sensitivity (Pre-amp: OFF):
    SSB, CW, RTTY Less than 5.6µV
    FM Less than 1µV
    • Selectivity (representative value):
    SSB, RTTY More than 2.4kHz/--6dB
    (BW: 2.4kHz) Less than 3.2kHz/--40dB
    Less than 3.6kHz/--60dB
    Less than 4.3kHz/--80dB
    CW (BW: 500Hz) More than 500Hz/--6dB
    Less than 700Hz/--60dB
    AM (BW: 6kHz) More than 6.0kHz/--6dB
    Less than 15.0kHz/--60dB
    FM (BW: 15kHz) More than 12.0kHz/--6dB
    Less than 20.0kHz/--60dB
    • Spurious and image : More than 70dB
    rejection ratio (except IF through on 50MHz band)
    • AF output power : More than 2.0W at 10% distortion
    (at 13.8V DC) with an 8O load
    • RIT variable range : ±9.999kHz
    • PHONES connector : 2-pin connector 6.35 (d) mm (1/4?)
    • EXT SP connector : 2-pin connector 3.5 (d) mm (1/4?)/8O
    ANTENNA TUNER
    • Matching impedance range:
    16.7--150O unbalanced*1 (HF bands)
    20--125O unbalanced*2 (50MHz band)
    *1Less than VSWR 3:1; *2Less than VSWR 2.5:1
    • Min. operating input power: 8 W
    • Tuning accuracy : VSWR 1.5:1 or less
    • Insertion loss : Less than 1.0dB (after tuning)
    Supplied accessories:
    • Hand microphone, HM-36 • DC power cable
    • Spare fuses • CW key plug
    This ad was posted by N0NUF SCOTT M GRAHAM, LINNEUS, MO 646539508 IP: 75.54.79.162
    If no email address or phone was given, click HERE to send N0NUF a private message.
    Oct 2001
    Missouri and Kansas
    Default Icom IC-756PROII Tranceiver
    I am asking $1,500.00 USD - Or best offer (OBO)
    Best 73!
    Scott - n0nuf
    10. Specifications
    GENERAL
    TRANSCEIVER
    60dB (50MHz band)
    More than 55dB
    RECEIVER
    1µV (50.0--54.0MHz)
    FM Less than 1µV
    ANTENNA TUNER
    I would like to talk too you about this radio please give me a call kj4hpw number is 865-816-4602
    This ad was posted by N4UBC Raymond E Lloyd, Johnson City, TN 37615 IP: 50.142.102.215
    If no email address or phone was given, click HERE to send N4UBC a private message.
    AUBURN,WASHINGTON
    2000 ?....
    This ad was posted by K7TOM THOMAS M SORRELL, AUBURN, WA 98002 IP: 70.199.135.195
    If no email address or phone was given, click HERE to send K7TOM a private message.
    Would you be interested in a Mint TS590S with voice recorder
    This ad was posted by KG0MN KEVIN J ELLIOTT, SAINT PAUL, MN 55105 IP: 75.168.84.110
    If no email address or phone was given, click HERE to send KG0MN a private message.
    Oct 2001
    Missouri and Kansas
    KG0MN: No thank you. I am trying to clear out some radios and make room for a 7700. Appreciate the offer, though.
    Take care,
    - Scott - n0nuf
    Oct 2001
    Missouri and Kansas
    Since I apparently can't close the first post, and can't edit any of the posts, here's an update to anyone confused by the mess above:
    IC-756PROII 100W Transceiver - $1,500.00 USD.
    Thanks,
    -Scott - n0nuf
    Oct 2001
    Missouri and Kansas
    Sale pending for $1,500.00 USD...
